Xiaomi TV Discussion Thread V [consolidated]
lance88
Hmm turn on already but my connected pc still didn't show HDR or 4k on Google Chrome Netflix.
I did another test on the TV pre installed Netflix and got 4k and HDR. Wonder what went wrong on the pc side...
KyawZO
Same as me as I'm using Samsung previously and it's too big to fit for 43" 4s.
I went and dig out all of screws I have in store room and luckily one batch fit. Tbh can't help to advise the size but it looks like one of those standard size screws. Best is to check manual or ask seller.
Thank you for your reply.
1a2a3a
Google chrome cannot run 4k for Netflix. Use edge or the Netflix app in windows store.
Thoma5
my friend just told me that tmr gt around 70 and 100+ on the monday xiaomi tv that need to deliver...
Those waiting for the tv,hope u all can receive the tv...
jfreex98
mine is coming today 4-6pm according to the delivery cum installer cant wait!
SkimMilk
Thks for your help.
The screen will show flickering distorted lines of colors or uneven shapes. Usually is quite fast and random like streaks of light.
seen it on built in apps like youtube and live channels. no hdmi attached.Really puzzled and no clue to resolve. tried olaying with all picture settings also cannot.
the image shown is captured when it is obvious and i paused the playback.
pls help.Do u think is a panel issue by manufacturer?
have you upgraded to the latest firmware? If yes, then I say make noise with them. keep making noise until they change the set for you.
Loser
28 april first order for batch 1, then bumped into batch 2 so i cancelled on 9 may (robomijia)
9 may reorder from minihelper. today receiving soon delivery guy late abit but its ok
How's TV?:s13:
nagase_4
I also must say it's a good grab. It's a beauty
For the price, it's really super super value for money.
Thinking of getting the 65" now, but not sure to get the 4S global or go for 5pro (did i get it correct?) for the OLED...
Only diff is that 4S global now is running TV Android while the 5pro still running the china or russia OS...
i1magic
You need to enable HDMI enhance mode to run 4k 60fps (required for Netflix 4k).
This forces it to run at HDMI 2.0/2.1. Otherwise HDMI 1.4 cannot run 4k 60fps even if all devices and cables are capable of running 4k 60fps.
You can search my previous post in this thread as a few bros have had quite a few sleepless nights trying to figure this out.
Do we need a "good" HDMI 2.0 cable to output at 4K @60Hz? Or will a "good" HDMI 2.0 cable give better picture quality?
roidred
Enjoy your TV. Anyway that a long wait. Hope you are satisfied and happy
jfreex98
Thanks! Enjoying now.
Got a question though any idea how to set the channel number onto the remote control?
For my parent easy usage. Like number 1 is channel 5 number 2 is channel 8.. instead of having to go to CH LIST to select from the list itself
JJJ010101
Hi experts.. I Googled for a bit but can't find a definite answer.. Hope someone can please help
Im interested in the 4S 55inch, but want to confirm whether it supports Dolby atmos passthru to soundbar via hdmi ARC
oinkoink1999
Talking abt soundbar. Did anyone get one to pair up yr TV to boost audio performance. I just ordered a mid range from lazada tech fair w good discount :)
Sent from HUAWEI YAL-L21 using GAGT
