Redmi K30 Series, Pro and Ultra
stylechap
Resealed one is it..:s22:
You want to compare your shrink-wrap against those unboxing video? Lol
wadsad
reseal set sure got (alot) bubble at the side one, the join part. very easy tell. nv see b4 a reseal set that looks clean.
last time i buy and got reseal set cause the seller need take out the china adapter and change to local adapter. the seller nv touch the phone. not from finer.
Anything_Whatever
Because some ppl no skill dunno how to re-seal the set... must use Clear cellophane sheet and hairdryer blow hot air to shrink wrap tight tight. Then use needle to poke release trapped air bubble. Factory sealed set usually use this type of machine.
If use thin plastic wrapper type must vacuum out the air and seal.... this type sealing cannot use needle poke poke to release air. this type of sealing usually done by shops for repacking behind shop backyard.
hdb2rm
Not sure how to embedd
Nakedtoes
If phone is locked... its still possible factory out got beta rom... i think i received before for one xiaomi phone years ago.... its beta rom but locked boot loader. that time i think new version MIUI out also... then the next update come the beta become full version... means k30 pro zoom miui coming real soon,,:D
Nakedtoes
Locked.
Anyone's set is play protect certified?
i remember mine is certified.... but u got follow my instruction go xda thread to download only google sync, calender and contact sync? only need this 3... GMS is inbuilt.. should be same for miui 12 beta
ranmaru1987
Bro.. u mean google play store, contacts sync, calendar sync these 3?
Sent from Xiaomi MI 9T using GAGT
garychengjw
uh? confirmed will come in miui12 beta from factory sealed set? :eek:
Beefsteak
Strange that they preinstalled miui 12 beta in the phones when its closed beta and not officially out.
