Can i know why you chose rhe 1660ti model instead of 1650ti?
When can we get the coupon?
Posted from PCWX using SM-G973F
Likely cause the jump in performance is big and worth the extra cost.
Between the 2, I still take rtx for gaming. But yeah rather have amd / 1660ti at lower cost. Not taking 1650 at any cost.
Imagine the temp if it has vents like gs65 / legion
Lol yah man, but temps wise okay, at home it's plugged into ext monitor and outside the screen is actually pretty good. Furthermore amazon did a rebate for my shipping so all in my tuf a15 only 1.5k
If you buy from shoppee, do you have to pay forwarder or gst?
No need. Direct. Taobao need.
Pulled the trigger.
Do note that 5cgo White 1660Ti is OOS
All inclusive? That’s cheap considering one of the cheapest rtx 2060 is from BestBuy and it’s around $2.2k with only FhdGotten a set from Taobao
Ryzen R7 4800HS(?)
Rtx 2060
1tb SSD
24gb ram
2k screen (yes, I picked 2k over 120hz)
White Color without the led matrix.
Damage is $2225.
Worth?
Shopee or TB? Think they increase the price for 1660ti in Shopee to 2299 from 2258
Shopee, pay a bit more to not deal with the hassle with gst and foreign exchange and forwarding.
2299 OOS, so I got 2339.
100 off shopee voucher
20 off shop voucher
12 off cc voucher
Too bad TB has language barrier and not straight forward as Shopee hahaShipping (To my address ) probably will cost another $$16.
So around $2251
Was thinking of sticking to legion 7I .. but.. oh well might as well.
App say 3 stock left though maybe they restock after you buy. Shopee set comes with the unnecessary aniMe matrix right?
Manual purchase from Taobao might save $100-$200 but there is a risk in missing parcel by local delivery courier.
And must pick trustworthy forwarder service provider to handle the shipping from China to Singapore.
A lot of factors here..
Why don't you all wait for awhile for Singapore Malaysia border to reopen and buy from Johor? It should be cheaper right.
