AMD Ryzen NB Discussion| Lenovo Thinkpad E495/E595/T495/X395 Well-rounder performance CPU + GPU
straweffigy
spent the whole afternoon doing these:
- Windows update
- Nvidia update
- AMD update
- install some of the games I wanna play... Pubg, Apex, CS GO, Valorant
I gave up Fortnite cuz the file size is way too big
CS: Go High settings: Ave 140fps, highest I saw was around 240 fps
Apex High settings: Ave 70fps, highest I saw was around 95 fps
These kinda games still okay.
Try AAA games in high settings.. will be lucky to get 40-50 fps :s13:
But luckily I don't play AAA games.
jinlong0
I think mostly whom bought a Lenovo laptop in this group is buy direct ba. Very difficult to give the local retail business. Retail business really need to buck up a lot in terms of customer service and aftersale service.
If both of this cannot be met, and if e retail can do returns and ok aftersales support. I feel that buyers are better off buying at e retail instead.
unless retailers can match or even beat the discounts given by lenovo, else i think it is very difficult
tszkitc
Mine both are
4600H, 16gb ram, 256gb ssd, 60hz 100% sRGB screen
Minus 18% LENOVO18, minus shopback 12%. Minus credit card 5% cashback
It works out to around $960 per laptop
Sent from Henabi virus using GAGT
Bro. Which credit card got 5% cash back?
yusoffb01
installed my cheap 1tb
yusoffb01
So you clone the SSD???
Can give a guide? I also thinking to do something similar
wont clone. always get blue screen. fresh install better after driver backup
yusoffb01
those with 4800H can you benchmark the cpu?
if you get 19k means the 6 core is 16% slower
dualshoc
- Windows update
- Nvidia update
- AMD update
I'm curious how do you get 240fps from a 60hz panel?
RyoHarusaki
dont bother clone your nvme ssd to sata 2.5" ssd
stock samsung nvme is much faster.
unless you plan to buy a new Samsung 970 PRO NVMe M.2 Ssd
then cloning is worth it
