bladez87
- Dec 13, 2008
.. anyone got any reviving method? if not i need sent back finer liaoz sucksPlug into computer and press power down vol.Oh nos....... My k30 pro zoom suddenly turn off after i just browse brave browser.... now cannot switch on.... plug charger no light..... press power + up button or - button also nothing happen..... sway sia..... manybe i encountered abt 3 time it reboot by itself during miui 11 are a sign..... anyone got any reviving method? if not i need sent back finer liaoz sucks
2020-06-22/周一16:35:33my another order now stuck dunno where.
no update since 22nd jun. by right should be with ups.
ordered on 16 june. anyone same boat?
Edl but you need to open up the back case, disconnect battery and connect the test point with authorised mi account.Oh nos....... My k30 pro zoom suddenly turn off after i just browse brave browser.... now cannot switch on.... plug charger no light..... press power + up button or - button also nothing happen..... sway sia..... manybe i encountered abt 3 time it reboot by itself during miui 11 are a sign..... anyone got any reviving method? if not i need sent back finer liaoz sucks
woah...1st case of bad device?Edl but you need to open up the back case, disconnect battery and connect the test point with authorised mi account.
Best is to send back to finer.
Sent from Xiaomi MI 9 using GAGT
If can get into fast boot, then u can flash fastboot rom.
Or try to charge it first
Sent from Xiaomi MI 9T PRO using GAGT
Oh no sad bro, how Long the set Liao? Will also like to see their warranty is it one to one exchange (used set m) or send back to China xiaomi warranty and how Long the time back and forth
Hi, for sms Apps, do you guys use the default Xiaomi or Google Messages?![]()
need to go edl means very serious liao
That's what I'm gonna do too.![]()
运输中
您的快件已到达【京东专线】,快递员为您送货,货运单号为
i still stuck here
Yeah swuay lor.. Electronic boh pian one.. Lucky I got spare phone. Phone use for 2 month only... But I think the 2 or 3 time restart is a sign.. So guys if u all encounter reboot out of nowhere just backup..
i use Google Messages previously, but switched back to Xiaomi default, the recent update to Google Messages unable to select the SIM to send the message. Because I am on dual-sim, i can select which SIM i want to send from, seems google message update bricked that.
Was your phone factory sealed when you received it?
Any signs that it was tampered with?
jialat... 2 month uplorry
my phone will lag+app hang![]()
