For isavvy FD, you get 0.25% upfront. Balance get end of 3 years
yesyes, isavvy TD min 25k with upfront int like u say.
Normal TD min 1k for 36m with interest at the end of 36m.
Chance upon this ad. I didn't go into details. Just in case anyone is keen
https://www.ocbc.com/personal-banki...2020:social:FB-IG:PPT-Interest:Static-Link-Ad
Given the current fd rate, should i put 6 mths instead of 12 mths?fixed deposits too low,I think endowment plan get higher returns of 3 to 4 %?
anyone can enlighten me the bad thing of endowment?
You can consider DBS FD 10/11 months@1.1%p.a. up to $49,999 which can be opened and placed online. To place more than $49,999 for 1.1%, you can consider opening another joint FD account which would be done at the bank branch.Given the current fd rate, should i put 6 mths instead of 12 mths?
why would it be 1.1%?OCBC Premier Dividend+ Savings Account
this is equal to 1.1%, correct?
max is never withdraw is 0.4%, if top up 2k monthly, add 0.4%, total only 0.8% max.
if got withdrawal then only get 0.05%
icic, but even including the $15 voucher for every 10k.$15 NTUC voucher for each 10K
15/10000*100% only 0.15%
so total only 0.15% + 0.8% = 0.95%
ah~ ic, only plan to put 6 mth then take out all.for 6 months only, so should be x2
Elastiq referrer quote
HUAT88
Share share with bro and Sista here
https://refer.policypal.com/c/HUAT88
Which bank now highest interest maybank or cimb?
actually now HYSA Plus is higher than both
