Redmi K30 Series, Pro and Ultra
24thchromosome
gpay works smooth as butter 😁
Congrats on getting gpay working! When you add your credit cards into gpay, did you get some small wordings warning that the credit cards can only be use for online purchases and not retail? I got that which is really weird...
xFidelity
thanks 😁👌 didn't get a similar message though. only noticed that the gpay singapore app does not work all the time and cards do not load.
decided to use the normal gpay app instead.
24thchromosome
Thinking just want to unlock and install TWRP. And use Magisk hide.
But I heard that some banking apps like DBS etc and Singpass can still detect root even after magisk hide.
Hi, before you jump onto magisk hide, have a read at these two articles. It seemed the days of magisk hide might finally come to an end with google being more serious than ever to end the cat and mouse game which lasted for years.
bladez87
ya read about it a while ago.
but decided to just unlock bootloader and see how ba.
MrRayded
Does this mean history works?
Sent from Xiaomi REDMI K30 PRO using GAGT
No, this is not location history. This is your google maps search history.
Location history is a record of the places you've visited, can be accessed by going to your google maps timeline
minuteez
https://help.netflix.com/en/node/23939v
Can I check if you guys can watch netflix in hd?
@johnsoneo was asking in 10X 5g thread why his 10X cant view netflix in HD even though its widevine L1.
I found the list of supported devices and its vevry limited. But I dont see anyone with higher end devices having issues with netflix HD
johnsoneo
Also still having problems with Whatsapp (and other messaging apps) notifications. Despite changing settings for autostart and battery saver MIUI seems to keep closing the app when screen is off for a while. Only after unlocking screen and opening the app does messages come through again.
Any bros here got a solution? Thanks.
davidwong
Open your WhatsApp lock your WhatsApp app in the recent apps interface by locking the app the background task killer won’t be able to kill off the task. That is what your 6/8 GB of ram is useful for.
And change or ensure the option to off wifi when the screen is off and lock
johnsoneo
Already locked the app in background task. Sorry where to find the option to off wifi when screen is off. Thanks.
davidwong
Please find below YouTube on how to lock app in recent apps to prevent background task killer from killing off the app
bridgestonelk
My WhatsApp is working properly on k30 pro.I didn't even need to lock app. I only enable auto start. What's your play store version and device certified?
Sent from Xiaomi MI 9 using GAGT
