[Club Discussion]AMD Ryzen Members Club
mrysj93
I'm planning on getting a MOBO+Ryzen CPU combo from Tmall.
Does anyone know if AMD provides international warranty for Ryzen AMD bought from Tmall/Taobao?
Kitaro9202
i think i might wols
finally got amd vce encoder for vegas pro
render a 40min video took below 10min
quite fast i would say
Ideasmiths
wah pianz....All my life been using intel, then someone suggested Ryzen say cheaper faster better....so I got a 3400G with B450 I AORUS PRO WIFI, installed windows 10 pro 2004, has samsung 970 evo plus, 650W PSU, 2x4GB Lpx ram (all parts canibalised from intel motherboard so all working) ...then the nightmare begins...
Frequently, it will freeze for a while (time random) when I launch Edge browser, or sometime it will just happens and mouse pointer stop, but keyboard ctrl-alt-delete works.... even when i touch the whatsapp desktop to bring it onscreen.
Googled and tried most of the suggestion, like change power mode to high performance, change to balance, change the PCI link power management, etc. Seem like Ryzen has this issue with window 10 since 2018?
Any hwz suggestion?
saif07
Any hwz suggestion?
well afaik that 2004 release of win 10 is indeed full of bugs.
btw have you updated your BIOS?
Charlie_Zhan
Any hwz suggestion?
have you downloaded the lastest chipset drivers from amd website?
royfrosty
Any hwz suggestion?
Then there must be somewhere hardware problems in your old parts. When you said it freezes, high chance your ram has errors on it. Try running memtest over a few hours. You should be able to see some errors in it.
Windows 10 pro 2004. This is one area you need to redo. This version has a lot of bugs unpatched. What you can do is get a thumbdrive With 16gb at least and download windows media creation tool and run it. Insert that thumbdrive first and follow the screen info.
Once you have done the windows 10 pro flashed into the thumbdrive. Its time to do a clean installation of windows 10 pro by inserting the thumbdrive and turn on your pc. Delete the partitions and make sure you install windows 10 pro on your ssd.
Only install the windows 10 when you have rectified the ram issue.
Kitaro9202
I notice some software like more biased for Intel like Adobe premier pro etc on amd render damn slow compare to intel
saif07
i beg to differ sir
watzup_ken
Any hwz suggestion?
Check those rams. LPX seem to suggest Corsair to me. What works fine on your original Intel system may only be optimized for Intel. I ran into major issues with a pair of Corsair LPX DDR4 3000 previously and it seems like it is not an isolated case. I have since steered clear of Corsair rams. I have a Ryzen 5 3400G running with an Asrock B450i with no issues on the latest Windows version. I am using Crucial RAMs instead.
Ideasmiths
Noted thanks, will try to switch.
Today win 10 updated the July 14, 2020—KB4565503 (OS Build 19041.388)) and for a while the issues STOPPED!. Then I itchy hand went to update the AMD software which download the 'latest' driver. Now microsoft edge starts acting up again (freeze when launch, and occasional BSOD!). I googled and I think it's the win10+driver as win10 turns on hardware acceleration GPU scheduling for edge by default AND win10 2004 got this pair with the driver which will shows up in settings->graphics->blah blah IF compatible driver were found.
Now the desktop is 'stable' and only Edge is jittery, so I switched to chrome and also use my normal firefox and so far no freeze.
Update 17/7/2020 Memtest completed no error
watzup_ken
I've been using Edge as well on Windows 10 build 2004, but no issues. Though I have not updated Windows nor AMD drivers to enable GPU scheduling. If possible, I would recommend that you try with another set of RAM, ideally not Corsair.
Ideasmiths
Hmmmm, thanks
2nd day of using a Crucial Ballistix Sport LT 3000 MHz bought from amazon sg. All the symptoms stopped and Edge no issue. So it was the ram
Which also means Ryzen is picky about Ram? (no wonder advertisement says Amd Ryzen ready
gld998
heng I use cheap ripjaws.. no such problem..
Sent from Godzilla farting and very hiong ar! using GAGT
flame2000
Hmmmm, thanks
If you go to AMD and check, you will noticed Corsair has the least number of compatible rams under their QVL. If you are building a AMD Ryzen system, I suggest one stay clear of Corsair rams.
https://www.amd.com/en/processors/ryzen-compatible-memory
limcc
Not debating if Corsair Vengence LPX has compatibility issue or not.
I bought the 3200MHz 2x8GB kit 3 months ago for X570TUF+R5 3600, at first it wouldn't run at rated 3200MHz but only 3000MHz. After updating the BIOS, everything went smooth. Was also running R9 3900X for a few weeks, no issue either. The RAMs were shifted to Asrock B450 Pro4 with 3300X last month, No problem whatsoever.
Charlie_Zhan
I'm running 2x 8gb 3200mhz overclocked to 3600mhz with a 3900x with no issues.
