lorettatay
- Feb 10, 2001
5 hours? Omg which link?I followed YouTube method..
Got gms to work after 5hours..
Sent from Samsung SM-G988N using GAGT
Is it possible to install gms in Mate XS now?
Can singpass mobile, banking apps, Netflix etc works on Mate XS?
Which method?I shall answer my own questions.
Tried two methods on YT and the second method works for me.
Now my Mate XS is installed with gms.
For me now every apps I need work flawlessly (except singpass mobile)!
Which one?There is one method that have both singpass and carousell notification work....
A lot leh and not every one canCan search yt...
Do you guys have singpass working?
yahLook for debugger ... all you headaches will be gone
Vouch by a very happy Mate XS owner here![]()
Agreed with uYah but u not concerned about security issues meh? I mean some apps are in work environment folder and those can be remotely accessed since it is used by companies to romotely control the phones
yah
Anyone tried running home automation apps like
Smartthings
Ring Video doorbell
Bond
Alexa
Google Home
LIFX
Philips Hue
Sensibo
Tado
Deco WiFi mesh
Anyone tried?
Yes, but u need to use the location enabled Google play store for the app. Obviously the apps that u want to connect to it need to be also from the same playstore
