blurblur123
- Mar 6, 2011
这个说法是对的。
但是由于我不是靠这个赚钱的,所以我比较有选择性。看一个人的八字基本上可以了解这个人的心术,让你衡量是不是要帮这个人。有时不是一定要给他做风水布局,可能是借机点化一些盲点。
recently I help to see a friend's friend house. He moved to a new house and seek my advice. after I see the new house, look at his bazi and understanding his motivation, I know this guy is going to the wrong path and I turned down his request.
Shifu, i'm going to the right path, no wrong motivation or any exposing motive
help me improve my FS to be useful for humanity please
hi all !
had a very filling long weekend.. recharge my mood a bit.. hahaha.
today primary one Registration day for phase 2C,, the P1-IS system failed me
I actually don't like to study. But I felt I have to follow a certain "mould" which is to be perfect even every aspect in order to be liked and accepted. So these sort of change who am I and what am I. If only then, I don't try to fit into a "mould" I will be different, however, I will get even more hate
这个说法是对的。
When will i have chance to change jod?![]()
But tuv shu shu said he dont want to see edmwers home for the fear of sexposure. I got ask him![]()
Maybe my 心术不正 also![]()
hi all !
today primary one Registration day for phase 2C,, the P1-IS system failed me![]()
Not you 心術不正。only I cannot see light, 见光死!
Sent from MI 10 PRO 版權@TUV2008 翻印必究 Lim Kopi using GAGT
Since you already on the right path with good motivation, then I believe you no need Fengshui can also cruise to success.
is it because i no chiobu spotted.. Actually is true.. i got very offended by my friend asking for free resources at my expense all for his wealth purpose. He is top class worshipper of money. Everything about money![]()
I go temple light candle make wish only a few things:
合家平安
增强智慧
病卷远离
With this 3 things and a bit of luck, confirm got ability to make money.
这个说法是对的。
I would say going after money is ok if it is legitimate way, the case I encounter before the guy has some bad intention so I feel uncomfortable to help him.
And the interesting thing is his Bazi and his house 流年 all pointing to the same direction so I can sense he is going to be in deep trouble.
The remaining of the year probably got no more chance.
真的是冥冥中自有定数。
See your reply very gek sim![]()
贪财没有错,但是如果是用不正当的手段我去帮他不是助纣为虐?![]()
