OnePlus Nord
xonix
Best to stay away from xiaomi phones. MIUI memory management is so aggressive that push notifications stop working a few hours after a phone reboot.
MIUI is the 1 single reason that makes me stay away from XM phones. Unfortunately, that's how they recoup their losses from cheap phone prices.
Evangion
Anybody pre-ordered (30 Jul) the 12GB/256GB model from the official Lazada store and told to cancel the order as they can't fulfil it till Sept?
"Dear customer, due to supply chain and production shortage, we are informed that OnePlus Nord 12GB version won’t come to Singapore in Aug. We are very sorry that your Nord 12GB pre-order won’t be able to fulfill. We have below two options for you.
Option 1: Keep your current order, we will send you Nord 8GB (same color as your 12GB order) + Two years warranty + Free Type C Cable + Free OnePlus Bullet Wireless Z earphone (value $99) + Free SG 3 Pin OnePlus Warp Charger (Value $45). The total value is more than $749.
Option 2: You can cancel the order. If Nord 12GB return to SG market in Sep, you can place new order and get the same free gift (Free Type C cable + Two Years Warranty)"
TBH, earphones and a silly charger isn't worth the difference in value between the 128GB and 256GB models.
leowweiqi
Anybody pre-ordered (30 Jul) the 12GB/256GB model from the official OnePlus Nord Lazada store and told to cancel the order as they can't fulfil it till Sept?
Buy from here cheaper
https://qoo.tn/BGkPCX/Q127339979
divineone
indeed. doesn't the phone already come with a charger
ranmaru1987
Hmmm.. to me the earbuds and extra charger seems more useful than 2gb ram and 128gb storage.. after all oneplus needs their own charger for fast charging..
Sent from OnePlus 7T using GAGT
Evangion
I'm sure most of us already have better wireless earphones. Plus the phone comes with the fast charger, why do u need another?
ranmaru1987
For me 1 in room 1 in living room.. or put 1 in office.. anyway univercell has ready stock but is export set.. 12/128 $575
Evangion
I have the Aukey USB C chargers. 1 in bedroom, 1 in living room, 1 next to sofa, 1 in office, 1 for onsite office use lol. So no more need for fancy chargers!
Just checked on Univercell. They say no stock.
benqdell
Won't qc fast chargers work on them since they are using sd anyway?
ranmaru1987
I don't think warp or dash charge will work with that charger..
Nope.. oneplus uses a diff charging technology.. they increase voltage instead of current.. so will charge at lower temps.. even cable also must use theirs then warp or quick charge will work..
Evangion
Still works. Tried on friend's OnePlus 8 Pro. What gave u the impression the Warp charger is some special OnePlus only thing?
leowweiqi
but why???
it seems to me that the 12 gb is in more demand than the 8 gb version thats why lack of supply
which leads me to wonder why people prefer the 12 over the 8 gb version
8gb is more demand than 12gb.
hellojeffo
Warp charge is indeed special for OnePlus phones only. Only other brand that can use warp charge is Oppo. VOOC charging by Oppo and Warp Charging by OnePlus is the same.
Your aukey is using PD, it's fast charging buy not warp charging.
Posted from PCWX using IN2023
