AMD Ryzen NB Discussion| Lenovo Thinkpad E495/E595/T495/X395 Well-rounder performance CPU + GPU
trenzterra
Anyway for those who want to change screen of their ThinkPads, this is the procedure:
- Buy screen from eBay/Aliexpress/taobao. If can match the FRU, even better, to get FreeSync support
- disable the built in battery
- Remove the screen bezel by working from the inside of the screen out (I realise this minimises the chance of the retaining clips on the bezel from breaking off). Ideally it would be good to get a spare bezel when you do the replacement just in case. Need to be very careful and conscientious during this stage cos got a hell lot of double sided tape/ glue to navigate around.
- remove the display cable and replace the screen. Unless you are changing from touch to non-touch or vice versa, you don't need to replace the cable
- depending on the thickness of your new screen, you may need to make some adjustments, e.g. add additional foam tape under the screen etc. This is recommended to minimise backlight bleeding (I realise the backlight bleeding on ThinkPads is mainly caused by the pressure of the bezel pressing against the screen). For me I used those index labels you can get from daiso (which is quite sticky) and stack them on top of each other until I got the ideal thickness where there is minimal backlight bleeding.
- put everything back together!
Now my next experiment is to replace the stock camera with the IR camera. Unfortunately I cannot seem to find a place which sells the necessary cables.
consigliere
I'm going to change the panel, add a 4G card, sim tray and the antenna as well. Hopefully it will work.
halocast
Now base price almost same as FRONTLINER code but FRONTLINER coupon doesn't reduce price.
LENOVOPRO X13 with 4750U only 1269. Whew
wha...... if can discount under 1k :eek:
T14 only got 1 model liao
trenzterra
T14
Ryzen 7 4750u
16gb
1tb ssd
250nits screen
1520 frontliner code does not work
Good price or wait for tiger lake?
Try LENOVOPRO if you have Lenovo pro account. Can get another 100 off.
Also I think 512gb seems more worth it. Buy your own nvme
Phrajile
How is this one?
$1199.25
Lenovo Yoga Slim 7 (14)
Processor: AMD Ryzen 7 4700U Processor ( 2.00GHz 4MB )
Operating System: Windows 10 Home 64
Display Type: 14.0"FHD IPS Glare WLED Backlight Narrow Bezel with Glass 1920x1080
Memory: 16.0GB LPDDR4X 4266 LPDDR4X Onboard 4266MHz
Storage: 1TB SSD, M.2 2280, PCIe Gen3x4, OPAL2.0, TLC
Warranty: One year Carry-in
AC Adapter: 65W
Graphics: AMD Radeon Graphics
Battery: 4 Cell Li-Polymer
Bluetooth: Bluetooth Version 5.0
Camera: IR & 720p HD Camera
Keyboard: 6-row Backlit English (US)
Pointing Device: ClickPad
Wireless: Intel Wi-Fi 6 22260 2x2 non-vPro
trenzterra
How is this one?
$1199.25
AC Adapter: 65W
Good price, but I will top up 30 or 40 dollars for the onsite warranty.
flowerpalms
How is this one?
$1199.25
AC Adapter: 65W
The graphic is vega? Can play game anot
Posted from PCWX using SM-G973F
Henabi
Seems it's about the same as GeForce MX250 (25w):
https://laptoping.com/gpus/product/amd-radeon-graphics-of-ryzen-7-4700u/
So I would guess light-gaming use?
Yes. You are able to do light gaming like Cs go, fortnite, DOTA, LOL with reasonable frame rates on ryzen 4000U series laptops.
Even my 3700U is able do play the above mentioned games with very decent frame rates.
Whereas Intel and their integrated graphics may be unable to do light games with decent frame rates but charging extrobiant prices
In the chart, it indicated that 4500U is same as intel Iris plus... But if you search YouTube with (Iris plus vs 3500U) or (Iris plus vs 3700U) or (iris plus vs 4500U, you will realised that even the ryzen 3000U series is able to produce 10-30% more frames than iris plus
Above is a gaming compassion video between
AMD ryzen 3500U with Vega 8 vs Intel i7 1065G7 with Iris plus
This weekend I will try gaming on my sister's laptop which is using Intel i7 10th gen with Iris plus and see how. Probably trying cs go and dota
Sent from Henabi virus using GAGT
Mystyque
iirc the price of the 1TB is close enough not to worth the trouble. Only if want to drop in a 2TB NVMe and/or a second 2242 NVMe then worth the effort.
SembCorp
I think 16GB ram only?
Btw, is the screen that bad? I bought one with 14.0"FHD IPS AntiGlare LED Backlight 45% NTSC 1920 x 1080. Like, NTSC? Errr
Oh saw wrongly haha. Still it has potential for 32gb ram so that's good...
Yeah it's quite bad to me. But of course your eyes and my eyes may be different?
I've just replaced the screen on my X13. Quite simple process if you have the necessary parts but I'm still tinkering with minimising backlight bleed due to the bezel sticker haha
I see! May I know what’s the difference ah? I just opened, seems okay for the NTSC 45% (though I don’t know what these means haha)
The more I use, the more errr I get HAHAHAHA!
The screen see already not shiok one. Trying to figure out what is wrong, perhaps it is too reflective? Maybe I am too used to iPhone and iPad screens. Even my work Dell screen not that bad.
LiNuxIDIoT
I m in a dilemma to wait for 1660ti or just go with 1650. Would like to game for abit in WoW and POE.
Sever
How is this one?
$1199.25
AC Adapter: 65W
hi, where can i get this offer?
