Same, amount not deductedanyone able to use bank voucher? i managed to claim a dbs 20 off 400 but amount not deducted at selection of card page.
use lazada mobile app for voucher to appear
I try checking out with posb card but the bank voucher never apply
Sent from My Phone using GAGT
Expired le mah...Most $30 off 200 voucher unusable
Bank coupons start from 9am...
Bank vouchers start at 9am. $30/$200 categories vouchers end at 12.30am
Same I also encountered unable to use on a $201 headphone but can use on $223 headphone, both items from the $30/$200 list
Ended up now the category voucher expired.
Did you check both product listings' directory path?
Quickly I tried on iphone can see the $30 off on the $223 item but not on the $201 item as the apps auto applied the seller voucher and there's no way to disable it.
I've never use shopee before, didn't know vouchers collected is like Lazada until the specific time then expired. At that time already past 12:30am so the Lazada $30/$200 voucher also gone.
The $201 item has seller's voucher $20 off applied but have the option not to use so i disable the voucher but the $30 category voucher still doesn't kicks in, I tried the $223 item also no $30 offQuickly I tried on iphone can see the $30 off on the $223 item but not on the $201 item as the apps auto applied the seller voucher and there's no way to disable it.
I also tried on shopee (I managed to collect all the 12am bank vouchers), seller voucher only $10 off, bank voucher $30 and if use VISA card to checkout there's another $5 off, total discount = $45 while Lazada is $30+$20+$5=$55 but I need to add another item to hit >$200
So I spent time on Lazada trying various items which none can help to meet the >$200 price, no idea why mouse, mouse pad not considered Electronics category?
No choice go back to shopee and found the bank vouchers all goneI've never use shopee before, didn't know vouchers collected is like Lazada until the specific time then expired. At that time already past 12:30am so the Lazada $30/$200 voucher also gone.
Ended up both platform also didn't buy.![]()
save your money. lazada sales isnt what it used to be. anw the system will always choose highest voucher so you could just check out.
