AMD Ryzen NB Discussion| Lenovo Thinkpad E495/E595/T495/X395 Well-rounder performance CPU + GPU
tjrsasea
Just spoke to some of my friends who do video editing...
They say that Adobe is still more incline towards Intel.. even though the 14 2 update enables HEVC but...
For premiere 14.3 it's seems like Intel wins again
As Adobe Premiere is able to utilize Intel iGPU + dedicated GPU for rendering, which offloads a lot of work from the CPU
But for AMD. It's just CPU + GPU
Which cause AMD to be slower
Still... For everything else, AMD faster than Intel,
Sent from Henabi virus using GAGT
yeap, PP leverage on intel's igpu for a faster export. Think the performance gains for amd will come eventually as adobe optimises their apps.
good to see that amd has caught up, good for us consumers when there is fierce competition. shall see how the next gen intel/amd perform and make my decision again when the time has come to upgrade haha!
editing is my main priority that requires a beefy cpu + gpu so intel is the way to go.. for now. for other everyday tasks like surfing/office etc i am sure either will work fine :)
Henabi
yeap... plus since right now AMD is offering better value-for-money.
why not haha!
tjrsasea
why not haha!
yeah why not!
anyways, my 5i order estimated shipping was advised as within 8 weeks before i make my purchase. OVP's estimated to ship date shows 4 weeks ytd and it dropped down to 14 sept now.
you guys will probably be getting ur legion 5 much earlier than expected :)
flowerpalms
yeah why not!
Waiting!
Posted from PCWX using SM-G973F
stillgottheblues
Lenovo Singapore said they are sending me the Xbox on 12 August 2020 after emails to and fro.
It will be 1 month tomorrow, I am in no hurry but is this the way to do things Lenovo Singapore?
Henabi
Really not sure.... First time buy laptops directly from a brand like Lenovo
Last time is buy from funan AD
flowerpalms
Xbox out of stock and they need re order. After all its not their own product what
trenzterra
Funan AD like boring. Only selling Intel models and very limited IdeaPads
tjrsasea
probably they forget already. need to keep prompting and emailing.
has happened to me alot of times. if you dont hear back after about 3 days means high chance you wont hear back again. have to email to remind again...
izaku8
ehm, i have same case. They do not have a good will to provide the gift if we do not follow up.
Who else here that have not received the xbox gift?
Klythios
sorry bros abit off topic but I've a question. How come my phone is so much faster than my laptop even though they're performing the same tasks and both on the same wifi network ah?
izaku8
can give example what task that you are performing?
some website check the devices before rendering the page. phone usually is lighter compare to desktop version
chaiscool
Cause windows is crap. Also, desktop os need to support a lot of things hence not optimized (background running telemetry / anti virus etc). Same hardware on dedicated task like server can be significantly faster, so it’s software problem.
Mystyque
It really depends on what you are doing. For stuff, the app is already optimized for the device when compiled so it doesn't need to worry/handle stuff that a general purpose desktop app/OS needs to worry about.
For others, I'm doubtful there is any off the shelf phone that can run apps in 6 virtual Windows/Linux machines faster than my laptop :D
tjrsasea
not really, it depends on what laptop you are using. if you are using an entry level $400 laptop with entry specs and you compare it to your phone with latest gen chipset, of course the phone is going to be faster.
but if you use a laptop that is well specced, i dont really see why it will be slower than a phone.
but, still gotta see what kind of task @kly is performing
tjrsasea
pls tell us more what kind of laptop and phone and what tasks you are performing. simple web surfing? gaming? edit video? wifi speed test?
Klythios
Thanks for the replies!! Hmmm, nice observation by Mystyque! Playing videos on the phone runs perfectly well as compared to the repeated buffering(at least once in 5seconds:s22:) on the computer webpage, even though both are on the same network, guess next time I'll use the app to watch lectures instead:s13:.
Using a lousy 5th gen intel HP laptop, serve me perfectly well in terms of websurfing/words/zoom and am getting a new one soon. Phone wise, using a Samsung S10e. Had to submit assignment just now, so I had to merge PDF files(total ~50mb). Using the same website to merge file, on laptop it showed ~30KB/s upload and I tried on my phone and it showed ~300KB/s. What's causing the discrepancies? I checked the wifi speed after merging and it showed 5/3Mbps(down/up), currently its 12/4Mbps. Or is it my wifi is just bad:s22:
In the end I use my phone hotspot to use my laptop sooooo much faster but waste data hahahaha:D:D
yusoffb01
u hotspot its faster. means laptop is capable. change.your router
tjrsasea
agree with yusoff that ur laptop should be capable.
from what you've described, it seems more of a wifi/network issue to me than the laptop's hardware. when you use ur phone you are at the same location as where the laptop is located? does your laptop support 5ghz wifi? my last 5th gen intel laptop only support 2.4ghz and always have some sort of connectivity issues when it is placed in a less than ideal location.
what is your experience when you use the laptop when its close to the router? got improvements?
try different scenerios, will help to narrow it down to what is causing the poor performance haha!
ceestudent
Surpeise with my custom order progress for E15. Ordered on 9 September and today shown expected to ship date as 18 Sept:D
