Recommend a Good and Cheap Air-Con Service Company
Ark Law
Sales rep pushing for Toshiba commissions lor. ME Starmex has better volume, so spare parts even if things go wrong in the future, are much better than if you go for slow moving brands like Toshiba, LG, Samsung.
Besides, ME is the most serviceable brand out there
tigerwoods
Gain City rep came to do site survey and recommended either toshiba or Mitsubishi system 1. He said toshiba was better, which I was surprised as never hear much abt toshiba aircon. Anyone has toshiba aircon?
Don't listen to them, do your own research. Toshiba they earn higher commission.
You can't go wrong with Mit or Daikin
Posted from PCWX using iPhone 1000 Pro Max
Mecisteus
You request to do a site visit to his house instead.
Check what aircon brand he is using. :s13:
shadow84
Shld i go for general cleaning on FCU 1st or just straight jump into chemical washing? Have a feeling serviceman may say need do chemical washing
tigerwoods
Aircon how old?
serviceman of cos says chemical wash cos can charge more.
a4973
Air still cold ?
You open the cover and see the coil, if all black then it's time for a chemical wash.
What if the front of coil is all silver and shiny but the output of air is in huffs and puffs? What kind of cleaning is required? Thanks
tigerwoods
First clean blower fan and filter.
acidobass
My aircon just got repaired from SgOzoneAircon.com today morning. The technician told me that they get approval to operate for aircon repairs, aircon not cold and water leaks. They said all aircon companies need approval to operate, they showed me the approval letter. Please make sure aircon companies can show you their approval.
Hope can help people who need urgent aircon repairs. call 67750378 :s12::)
Cant say I had a good experience with SGOzoneAircon. 1st time booked with them for regular servicing. When the guy came down (Keith or kenneth or something) he said my aircon condition was bad and needed chemical overhaul. Took his advice and paid $150 for 1 unit chemical overhaul.
2 months later, yesterday, 2 technicians from another company doing regular servicing showed me that it wasnt even a proper chemical overhaul and was done poorly as the fins at the back werent cleaned at all and choked. They explained how a proper chemical wash should be and that theirs involved more thorough steps and at almost half the price.
Will try theirs next and update.
Sucky feeling but I blame myself for not doing more research.
yyoqwerty
Highly recommend
Mr. Kenny: +65 9425 8444
I was referred to him by my friend,
and he provided the best aircon service.
honest, great service,
fast reply, and punctual.
I contacted him around 8pm for aircon servicing,
and he come the next day 12 PM,
almost on the dot.
hanoraptor
Help fault indicator on fancoil
Hi all,
Anyone know what is the error code for MHI, the fancoil unit is flashing green and amber for power, timer and not able to turn on. The technicians confirmed that the pcb is faulty and asked me to replace. The cost of the pcb is $180. My aircon is less than 3 years old.
MrRainbow
Wow how come your pcb so cheap. Can you share technician contact and name please?
My pcb faulty as well. Mitshibishi inverter aircon
Hi all,
Norman Chan
Able to share presently what is the market rate for the following service.
1) Service per fan coil - S$20/S$50
2) Chemical wash fan coil - S$80
3) Wash out door unit - S$80
4) Chemical wash out door unit -S$80
5) Refill refrigerant/gas per compressor unit - S$80
6) Vacuum (to clear oil slime) per compressor unit - ???
7) Vacuum (to clear water slime) drain pipe - ???
Ch3tah_39
Actually i sometime wonder these aircon servicing will cause the aircon to breakdown? Cause me seldom get people to do servicing for aircon. but got once, service liao aircon suddenly cannot on anymore.
MrRainbow
I also wonder...suspect if they can actually secretly do something to spoil the aircon so we will re-engage them to fix. But im not knowledgeable in aircon parts so will not make any accusations. But i am curious
MrRainbow
Hi, so did they do anything to cause it to spoil? I experience similar aircon not blowing cold air after the chemical wash. Ofc not immediately, but within the one month.
Upon checking, the motherboard (pcb) and fan motor in compressor unit was spoiled and melted due to trapped moisture.
Not sure if this is related or mot.
Norman Chan
If engage back the company that install your sircon to do the servicing will it be more safe?
Some third party maybe initially cheap but in the end cost more. What do you guys think?
