 Watch Series 6
FatalityV
the solo loops look very uncomfortable.
Is the sports loop similar to that of the old straps? the old straps look way more comfortable to me, although I will probably end up using a NATO aftermarket strap
PetPet
Moderator
Moderator
Ikr. It looks uncomfortable, but after trying it out in the store. I had a different take haha.
alvino
How to check? I have a graphite 44mm stainless steel also
In your iPhone’s watch app, tap on top left “all watches” you will see the watches you have. It will show the models and material and size there
skpuppy
Haha! Yes. Mine is reflected as 44mm Aluminum. Cheong SS. Lol
Snoweagle
lucky for you. Damn irritating when I see that.
My only ‘bug’ was the ECG issue I described earlier in this thread. Same as you, did lots of unpairing and re-pairing, three time from backup and three times as a new watch but ECG app refuses to appear even though the phone’s health app says enabled for my watch.
So all it takes is a simple reset of settings on the phone and solved. :s13::s22::s22:
Attila
braided solo loop look good.
i had a measuring tape from apple store and it measure size 11. but actual size 10 is more of a better fitment
layzibum22
Hmmm... why Apple Watch don’t show the heart rate number on the face ah?
Ok maybe it’s the face. I found one that shows.
alvino
just use cardiogram and add it as complication. dont work perfectly but at least something la. most times it just report heartrate recorded 30mins or hours ago.
i suspect it could be due to how apple handle multitasking just like ios.
i just went for a swim with the s6, workout didnt record any blood oxygen info. anyone tried it?
layzibum22
I changed to a face that shows. Maybe it’s the Nike face. Still exploring.
edmwperson
Should I hoot a watch?
Love it's Health functions, but dislike the short battery life
Don't need it's cellular function.
Material type preferably can last as will use during sport activities. Won't corrode etc
layzibum22
Hoot cos got chance take voucher from Gov. 😅
bluegt
I'm getting 40+ hours per charge on the GPS model - quite good battery on the latest model.
ryan_khoo
What watch face you use ?
And how u get the 56 and the 57 ?
Thanks
ryan_khoo
Oh yeah, i basic question.
How to take out the strap ?
To fix the strap, i just slide it in but to undo the strap, I cannot slide leh ...
Any ideas ?
Thanks
