kitsura
- Jul 20, 2002
So there are retailers who sell below rrp?Sounds like RRP to me...
P*** M*** but i have been going to them for quite some time now so i'm still ok paying rrp. Maybe there are neighborhood optical shops that have lower overheads that can quote much lower (not sure if such shops would stock Lindberg). I know JB easily can get the same lense at a steep discount but now that i am unable to go over just have to settle with local pricing.Maybe like 10% off or smth... 100% sure there are
Edit:care to share which shop quoted you 840?
According to Lindberg dealer list looks like no. Best call and ask.btw, do KJ Op (PS) carry lindberg?
Ah, probably if they sense more interest or if you try nudging them abit then it’s possible.
Unfortunately Lindberg don’t just allow anyone to sell their products.
There has to be a certain grade/requirements to be met before Lindberg will allow them to sell the product. More of a brand choosing the shop rather than the shop choosing the brand. So neighbourhood selling it.... hard to find. Lindberg also has a strict Priceline to adhere to, I heard of places being issued warning by them to keep the price at a certain range.
Again Lindberg is not your typical Cartier, Prada , Gucci kind of frame. Those who wears it will understand the design, weight and comfort of the frame. Other countries e.g. japan, hk when I went over does sell certain Lindberg models at a higher price too.
how does japanese frames like yellow plus, waza..etc compare to lindberg?
Their buffalo horn frames look very nice. Maybe next time when i strike toto can consider.To add on, I know a number of individuals who got discount on their Lindberg at taka side. No harm trying to cho cho them.
Is the unica ones those that cost 3k or more than that?Hehe I have one too. But I am aiming for their unica buffalo horn. Slightly more expensive but the marbling looks much better.
Any stores you recommend for this? I'll probably only be heading down in about 2-3 weeks after I clear most of my work so any part of SG is fine hahaMaybe you can spend abit more for a frame like yellows plus, lighter, more comfy than rayban but cost about 480? Should be able to last 3-4 years minimally with care. With blue light lens 350 degrees, the frame can hide a 1.50 index thickness lens. So add up... 570?
70 dollar overshot Budget but good frame. Would you be interested?
Sent from OnePlus 7 Pro using GAGT
