- Sep 16, 2018
For higher end and mid-range Asus router, please go to the other thread.
https://forums.hardwarezone.com.sg/...-rt-ax5400-tuf-ax5400-and-tuf-ax4200.6315347/
Note: I do not recommend lower end Asus ZenWiFi series like ZenWiFi 4/5/6 (okay as mesh node after a powerful router like TUF-AX6000, RT-AX86U, RT-AX86U Pro or GT-AX6000) as they seem to have multiple issues as reported in this forum, especially when the main node is also the main router.
If you want to upgrade from the list of Asus routers here, you can consider TUF-AX42000 at around S$249 in September 2023.
For the routers covered in this thread. All of them have relatively weak CPU BCM6750/6755/6756, similar to the CPU in RT-AX82U V1/V2 and TUF-AX5400 and ZenWiFi XT8/XD6.
1. The following routers are more recommended compared to the lower-end ones as the main router.
Mid-low end (512MB RAM, USB port): TUF-AX3000 V1/V2, RT-AX58U V1/V2, RT-AX3000, RT-AX56U (EOLed by Asus)
2. The following routers are more recommended as AP or AImesh node, not as main router.
Low end (256MB RAM, no USB port): RT-AX3000P, RT-AX57, RT-AX56U, RT-AX55, RT-AX53U
Notes:
1) China version of RT-AX56U V2 is similar to RT-AX55, not the same as RT-AX56U.
2) Chipset info for reference (not always correct)
http://en.techinfodepot.shoutwiki.com/wiki/List_of_802.11ax_Hardware
3) TUF-AX3000 V2 has a 2.5G WAN port. All the others in this thread do not have 2.5G port.
4) Merlin FW Support
RT-AX58U V1 is officially supported by Merlin FW, but not RT-AX58U V2.
RT-AX56U support has been dropped from Merlin since Asus has EOLed the model.
TUF-AX3000 V1 is supported by gnuton Merlin fork but not TUF-AX3000 V2.
The other models are not supported (including TUF-AX3000 V2 and RT-AX58U V2).
5) OpenWRT support
RT-AX53U and RT-AX1800: officially supported since version 22.03.
TUF-AX4200: snapshot release
RT-AX54HP (it seems to be similar to RT-AX1800HP): snapshot release
Reference:
https://openwrt.org/toh/views/toh_available_16128_ax-wifi
6) M1 RT-AX3000P (or previously RT-AX55) vs TP-Link Archer AX72 (FAQ)
https://forums.hardwarezone.com.sg/threads/which-router-is-better-asus-or-tp-link.6952537/
Edit: remove RT-AX82U from this thread as it is more mentioned in the RT-AX86U/RT-AX82U thread.
Notes:
5) OpenWRT support
Reference:
