Macbook Pro Screen Repair
itaintnad
Anyone knows a reliable and cheap place to fix screen damage for macbook pro? Water is stuck behind the retina display.
reddevil0728
Why will there be water stuck behind the display? Accidental splash?
Apple is definitely most reliable, but definitely not cheap but at least you can be sure it will work.
Chrislzj
Better to go back Apple for servicing because if Apple detect that you are using unauthorised parts for replacement. Your device might get locked during the next software update. Just like my old iPhone X which can’t use the face ID
reddevil0728
but mbp no faceid
lensflare80
U can try Mac.Infinity at Funan Centre. I send my MacBook Pro there for the speaker repair n they did an excellent job.
davi502
Apple might deny you service as it might be considered as unauthorized modification if it was serviced by a 3rd party previously.
