Google Pixel 4a
trento
Difficult to remove or residue ?
Do elaborate.
Once applied, the product is not meant or made to be removed. If you've scratched the liquid protector, you're supposed to buff the scratch out with wax (or toothpaste). You can also apply anew liquid protector on top of the original, but this is not advised as it may pose problems with the operation of the device
https://www.quora.com/Can-I-remove-the-nano-liquid-screen-protector-It-made-a-scratch-on-my-screen
xonix
Eh...mine is just normal TG. Not the fancy liquid screen protector. :)
I think you confused it with another product.
Sen
Lucky~
Just hooted S$449 ~ Hope got shopback also.
Think S$25 mastercard no more.
Blueberrytea
Weird problem recently.
Suddenly open up camera then pic doesn't focus. Have to either shake so that the ois will focus or switch to video then back to camera before it focus.
Clear storage, reinstall camera app and clear cache doesn't help.
I side loaded a gcam app from xda but still use back the stock cam app and issue resolve. Opens up fine now the stock app, straight focus.
Later then uninstall sideload and see how it goes.
Edit: just uninstall sideloaded camera pk app, stock app seems fine now.
Never faced this particular issue b4...
Send for repair?
KGuanZ
Is it normal for the nfc icon to be grey under the scroll down option? There no way to tap on the nfc icon to on or off it, have to go into setting to turn on/off the nfc function?
Sen
Yup correct.
xonix
Sad but true. It's almost as if Google wants to force you to use contactless payment ( Google Pay ) by not allowing to turn it on/off. I am personally very pissed by this direction.
To make things worse, all one has to do to make payment with your phone is to wake the screen. No unlock required unless for larger amounts.
xonix
By the way, we need root access for 3rd party NFC toggles right ?
