Huh u try swipe down from top rightAbit not used to iOS, last time swap down screen can dim or silent phone Liao
Posted from PCWX using Rem mm is best waifu
U should get the control panel leh
Where u can control the volume and brightness mah
Mine around the same sot 3hrs battery left 56%
Somehow this morning 6am hwz app is running background for almost 1hr...battery life drop 8% when i am not using and phone is quite warm
Yesterday i managed to hit 8hr SOT
Usually noRunning background means never close the app?
Do you all close the app after use?
Posted from PCWX using ONEPLUS A6000
Ya usually no but dont know why that period its running at the backgroundRunning background means never close the app?
Don't think I can ever get used to not having a smart dial pad that allows you to start dialing numbers by keying in your contacts' names....You'll get used to it as time goes by.
You can use search to callDon't think I can ever get used to not having a smart dial pad that allows you to start dialing numbers by keying in your contacts' names....
Or not having spam messages automatically blocked, natively without installing any third party apps...
These are my pet peeves with iPhone.
Ohhh this is new to me.. not very intuitive, but I guess it's better than not even having the option!
No meh? I thought quite straight forward
Inside phone app, theres contact leIt's not intuitive to me cause when I wanna call someone, I intuitively will go to the Phone app. It's easy to search, just not intuitive.
can do things straight from e Home Screen is very intuitive to me.
You see which want you preferDo you all use truetone or didn’t use it at all? Dont even know if it help to relax the eyes
