squarepipe
- Jun 30, 2018
I never use USG before, is there GUI for configuration or purely CLI? How does it compare to the latest Asus ax88?
Btw, how's the wireless performance on HD? Do u get good connection speed?
Thanks
The USG runs off the same controller softwate as the in wall AP. Basically if you use the unifi AP, unifi switch, and USG you will be able to configure everything form one interface.
Asus is a home router while the USG is a enterprise router used in businesses etc. Those 2 aren't even on the same league.
I used 2x unifi HD aps to cover 3 floors of a house and I can get 800-900Mbps tested with iperf everywhere in the house including the garden.
