I am suggesting to get MKS65 or MXY3G28. As their rated capacity is 20-21k and you turn on 2 bedrooms most of the time, you can consider to upgrade one of the 9k indoor unit to 12k. This will allow you to maximise the rated capacity of 20-21k from these 2 outdoor units.
If you choose to keep to 9k for all bedrooms, it is ok too. Since you turn on 2x9k most of the time, it is within the 20-21k rated capacity. No performance loss.
However, upgrading 9k to 12k usually is very affordable. Some air con company even throw in free. So, can consider.
Are you suggesting upgrade master bedroom indoor unit? I often seee this recommendation. Curious ah but why? If Mbr and another room same size. Should it be use both room same btu and upgrade compressor outside?
