Looking for 3060Ti brand recommendations
Severon
Recently the games I played are mhw and cyberpunk 2077, both are having real bad framerates on my 1060 3gb. It's been awhile since I have built my pc so I quite out of it.. Another thing is should I get corsair rgb 16gb 3200 from amazon or local sellers for lifetime warranty as I read amazon don't give warranty for some.
Thanks in advance
Sent from Xiaomi REDMI NOTE 8 PRO using GAGT
Kairos
IMHO, local stocks, Asus, Giga & MSI (triple fans); overseas stocks. EVGA (triple fans). ;)
Severon
�Thanks for the advices , I dont think I can put a triple fan due to fractal meshify C and 2 140mm fans in front
Phen8210
ystoh133
Hi, I have a meshify C, using a gaming OC 3070 with 3 120mm fans infront. It fits nicely! just check the length of the gpu
Severon
Alright thanks for the advices, I will figure out which to buy!
Posted from PCWX using CPH1835
hafiz116
I'm testing the 3060 Ti Aorus Master by Gigabyte and so far I'm very impressed. It's not the cheapest card but well worth it if you ask me. One of the reasons for the premium on this card is the display thats can show a lot of good info about the health and even the frame rates you are getting while gaming.
So yes I completely agree when buying GPU's its highly recommended to go with the bigger beefier cards with a triple fan design to help keep temps under control. Also make sure you have good airflow incoming and exiting the case.
This card is basically the same dimensions as the 2080 Ti Aorus Xtreme so will not work for small form factor cases such as the NZXT H1. Below are some images and I will be posting more info in my build using this card,...
wwenze
With the reliability of electronics nowadays, get the one with the best warranty.
gonnie
wow this is nice, got lcd screen for thermals, and is that z73 cooler? cant find this cooler anywhere now..looking for 1 :/
skrekro
Honestly no point buying expensive low/mid-range cards when you can spend a tiny bit more for the next tier imo.
I always recommend getting the cheaper at least 3fan for low/mid-tier cards
hafiz116
No that is the Aorus liquid cooler 360.
The LCD on the GPU is more useful than you may think as it can cycle a lot of other information including FPS :)
As for the comment about getting a cheaper 3 fan card - yes I agree but if the user does not want to stretch too much to get a similar card in the next tier up going for this card is not such a bad move if you ask me.
If the user wants to stretch up to the next tier (3070) and get the same card model then the increase in price is quite a big one $250++ which may not make it attractive anymore.
TabascoSauce
I jus got gigabyte gaming oc with 3 fans. Tried far cry 5 at ultra setting and it runs coolly.
Don’t support Msi. They threaten reviewers that point out issues with their cards. And they were caught scalping their own 3080 and 3090 through its subsidiary
hafiz116
Here are the options of what you can display on the Aorus GPU's with an LCD,...
Severon
Well looking at the 30 series, the price steeps
moemoemoe
Anyone know where can still get 3060 ti for retail?
Check with a few stores in sim lim all OOS.
caden0325
Alot of shops run out of stocks for 30 series cards. everywhere shortage, hope they restock soon. planning to get a asus tuf 3060ti for my gpu upgrade.
