Citibank SMRT Card
hwmook
Not for me. Send them message to close my maxigain accounts. They ask me to confirm. I reply confirm and they say will close on 31 Jul. Till now, the accounts still there.
I close my maxigain account in dec2019 by sending them the message using Internet banking.
Adi Dassler
Anyone every month diligently monitor the cashback amount that is correctly reflected in your statement every month?
Sometimes I ownself calculate the rebate like they sneakily shortchanged me by $$0.10~$0.20. I know ish not much, but if every month keep shortchange will accumulate. :(
cassowary18
You got hit $300 minimum spend? If not remember to minus 0.3% from the cashback rate.
chiokcc
I check once a week or so. Sometimes give and take a few cents ....
What I dun like is that even when you login to Citi online, they never give detailed breakdown of the SMRT$ rebate. Unlike Rewards card, you can tell clearly which transaction reward you with the points.
duhduhduh
You got pay annual fee anot.... :o
lucky_
I have a couple of refunds incoming for this card (via online spending). First time processing refunds for this card so unsure about the following:
I presume Citibank would claw back the 2.7-3% rebate for these refunds, but will they also increase the $300 minimum spending to get the extra 0.3% rebates for the month that the refunds are posted?
Otokiru
i got $441.89 SMRT balance, is there any easier way to rebate off cc bill?
mubz96
Do u mean to use your cashback rebates to offset your balance? If yes, you can just redeem either block of $5 or $10 cashback rebates via sms to credit into your credit card which usually shows up a day later.
Sent from Samsung SM-G950F using GAGT
chiokcc
Otokiru
