How do I install the Wireless@SGX app onto my laptop?
Windows system is can install the App?
Anyone from GovTech or purple shirt Digital Ambassador can guide me how to setup?
addict951
High Honorary Member
Oh no... ts, this is basic comp knowledge leh :o
You access wifi points from the wifi icon at the bottom right.
ts, how old r u ar? Are you in your 50s?
Can is can
But cannot connect to wireless@sgx unless go download the app
How do I download a APK file to work on a windows laptop?????
Intrinion
Senior Moderator
Senior Moderator
There’s a zip folder for you to download for windows operating system.
Then run the exe file like how you install normal windows programs.
Can is can
addict951
Can is can
Why u need to download apk file for windows laptop to run wireless@sgx app?
Just click the download for windows file, use winzip to unzip and then click to run the wireless@sgx file.
danny8x8
Why need to download the app for those using sgx on handphone? Just connect and in the sgx settings change the security or something to sim can liao. No meh?
Edit: i think it's authentication, set it to sim.
Intrinion
Senior Moderator
Senior Moderator
Wah, really gotch software one
ts, see this link for Windows setup
https://www.imda.gov.sg/programme-listing/Wireless-At-SG/Windows-Setup-Guide
@ thread starter, kindly follow this step to install Wireless @ SG for windows on your laptop. It's a windows exe application, not apk which is for phones.
mouseking
I have windows11, the installer stop once it discovered my version of microsoft edge is the latest.
So, unable to install.
batuchka
if chui also carrying hamfone wif data plan along wif laptop either hotspork or usb tether loh
