Xiaomi air purifier?
Mr BBFA
Anyone using? What's the diff between 3c and 3h?
Filters wise both can use the same filter right?
Where to get from? :s12::s12::s12:
amazingone
xiaomi air purifier can find cheap filters to buy from taobao
Posted from PCWX using HUAWEI ALP
Apparatus
Re
Spray some nice scent and you don't need any air purifier
:D
Mr BBFA
stop farting at home and you will no longer need the purifier
:D
my main concern is dust leh, not so much about removing the smells / other bacteria :s13:
the xiaomi air purifier 3h seems to be the best value for money
but cannot run after the filter reaches '0'% seems a bit sucky
yah i see on shopee extra filters around 30+ 40, dont know how long can they last each time though.
bluecutie
For sg air about 6months replace or 3m if u kiasu
Tschuus
I used it for a year plus oredi ... still have 4% left. i dont on it all the time. Just 6 hours daily.
FINE_01
Able to use out of the box or need to connect to the wifi?
sTiCkY
do u open ur windows?
if yes, don't bother :s13:
u "filter the air" liao.... open window... dirty air comes back in........................
bluecutie
you using one currently?
the filters cannot vacuum or wash one right, once become 0% cannot continue running already? :eek:
U know how air purifiers work or not?
U simply need a fan and a box of hepa air filter
Basically I can buy a filter for $30 and just tie to my.fan and it is a functioning air purifier
Mr BBFA
no never open windows leh, the purifier for aircon room only :s22:
but ready made ones more convenient mah :s13:
so far the cheapest / best value ones?? i've seen is xiaomi only
Macrossvin
Jus press reset button to tell the machine that u change mah
sTiCkY
each xm filter is designed to last 180 days... 2 filters a year...
moi using xiaomi air purifier 1... no limit one...
moi will run it for 3 months past filter life b4 changing :s13:
