what a lousy article. this is one example that people only look at the positive aspect and ignore the negative portion. a typical salesmen talk.
it states that 2x ers = 550k at 55. that will give a payout of 4.6K per month.
you buy a property of 550k and collect rent, it is unlikely that you collect rent of 4.6k per month.
is he correct? yes, but he left out the negative portion of cpf.
if you buy a property at 55, you collect rental at 55. if you put into ers there is no return for the first 10 years.
if you are on standard, you die at 80, you leave nothing for your kids. if you die at 80 with your property, it is definitely worth a few hundred thousand, maybe more than the 550k that you put in.
i am not saying the cpf is no good. there are pro and cons. he should have laid out everything and let the people decide which is best for themselves.
the again, this is the state's times. i doubt any writer dare to say bad things about our state's system.
