- Sep 16, 2018
Xiaomi BE/AX routers Chinese models Year 2025 summary -- in Chinese
https://zhuanlan.zhihu.com/p/398448368
Currently only Xiaomi AX3000 (single or dual pack), Xiaomi AX3200 and Xiaomi AX9000 are available in Singapore. They are global version.
Xiaomi AX9000 has its own thread so it is not covered here.
https://forums.hardwarezone.com.sg/...9000-gaming-wi-fi-router-with-wifi-6.6489376/
Xiaomi AX3600 has its own thread as well but it has been made obsolete by Xiaomi (no longer available).
https://forums.hardwarezone.com.sg/threads/aiot-ax3600.6241076/
Xiaomi 1000/7000/6500 Pro, AX6000, Redmi AX6000, Redmi AX5400 Gaming, Redmi AX5400, Redmi AX6S and Redmi AX3000/AX3000T only got China version.
Xiaomi AX3000 (1 pack and 2 pack) got global version and China version.
Xiaomi AX3200 seems to be only for global version.
1) Redmi AX5400 gaming edition with 2.5G port and gaming port: https://www.mi.com/rm5400
2) Redmi AX5400 non-gaming edition: looked the same as Redmi AX6S, no 2.5G port
3) Xiaomi AX3000 mesh system (global version): https://www.mi.com/global/product/xiaomi-mesh-system-ax3000/
4) Xiaomi AX32000 global version (MTK CPU): https://www.mi.com/global/product/xiaomi-router-ax3200/
5) Redmi AX3000: similar to Xiaomi AX3000 but with external antenna and a bit lower cost, China version only.
6) Redmi AX6S (MTK CPU): AX3200 rated, probably similar to Xiaomi AX3200 in terms of hardware spec, China version only
7) Redmi AX6000, new MTK Filogic 830 CPU, no 2.5G port
8) XIaomi BE7000 dual band (recommended) or configurable as triband (BE7000) at about RMB899, with high end Qualcomm Networking Pro 820 CPU (quad core Arm Cortex A73 1.5GHz CPU), 1GB RAM, quad 2.5G ports
https://www.mi.com/xiaomi-routers/be-7000
9) Xiaomi 10000 triband (BE10000) triband with Qualcomm Networking Pro 1220 CPU (top of the line CPU, IPQ9570), at about RMB1799. 2GB RAM, 256MB Flash. Dual 10G port (one copper and one SFP+), quad 2.5G Port, USB 3 port, Docker support
https://www.mi.com/xiaomi-routers/10000
https://www.qualcomm.com/products/i.../networking-device-finder/xiaomi-router-10000
10) Xiaomi BE6500 Pro, lower end compared to Xiaomi 7000 (with lower end CPU IPQ5322, quad core Arm Cortex A53 CPU at 1.5GHz) but with Xiaomi IoT Gateway function, quad 2.5G ports.
https://www.mi.com/xiaomi-routers/6500pro
11) Xiaomi AX3000T, low cost router at around RMB189
11) Xiaomi BE3600, low cost China version of WiFi 7 router (no 6GHz band, no 320MHz channel width).
12) Xiaomi BE5000, low cost China version of WiFi 7 router (no 6GHz band, no 320MHz channel width).
