- Sep 16, 2018
I am thinking of having a Tuf-AX3000 at D1, maybe the 5G signal can still be strong at BR3.
There is a 8 port switch in the cabinet behind the main door(D1-D6). Initially, I had placed the router at the cabinet using D3 to connect to ONT and D4 to connect to another switch at the TV console. But I find the 5G signal is very weak in the kitchen. So I reconfigure the router at TV console (D3 and D4). Thinking of adding another router AX3000 at D1 to create an aimesh (and reduce the number of switches).
You can try TUF AX3000 at D1 in the maater room to see if that is okay for the bedroom 3 or not. If not you can get another RT-AX56U at D6 in the bedroom 3..
