DIY or Buy Ready CPU bundle?
jq75
long time no deal with diy.. a bit lazy and rusty
thinking abt getting a new desktop, mainly for work purpose and occasional (simple) gaming system.
prefer to hook up to TV panel so tt display can be used for TV as well as monitor
budget wise best is 'cheap and good'..
experts here, what would u advise?:o
hg2
Depending on you skills... we cannot answer for u...:s13:
It's just a commodity...I would just order online from Lenovo/Dell... and enjoy!!!
wwenze
Normally I will DIY because I seldom buy a full set at one go. CPU/mobo/ram, GPU, and storage are upgraded as I see required.
My TV rig is now an old laptop.
86technie
You have to consider are you able to troubleshoot where there are issues?
A set like this from lenovo around $1000 with three years onsite warranty.
https://www.bestdenki.com.sg/desktop/lenovo/ic-3-90nb008ast
Dreamcore or aftershock despite there is warranty but it's not
next day service.
Example if RAM spoilt they have to RMA which take some time.
Branded wise if they have parts available they can service within
three business days.
I would recommend you to get branded, FYI the warranty can
be extended after it expire.
localITguy
Suspended
depends, if you have the time to diy/send for repair if things breakdown than okay. go with diy.
if you don't want to deal with all these, get a pre-built from dreamcore/mansa/thypoon systems
i have purchased from aftershock for my desktop PC and i can tell you. the service is subpar at best
I would not recommend Aftershock, based on my personal experience.
really give me an After-shock
wxnetworking
are they value for $, some shops in SLS also have such service, but need to do some homework:D
Dreamcore/Aftershock are quite competitive in pricing compared to SLS. Ultimately, you can drop by SLS and ask them to give you quotation with the requirements that you have and compare them to Dreamcore/Aftershock.
Generally, I heard better reviews and service on Dreamcore. I have friends that brought PC from Dreamcore and are quite satisfied.
RyoHarusaki
If you just need a pc to watch videos and hook up on tv. Just get a cheap laptop.
If you are into gaming and intensive work. Diy?
pewpewcat
Correct me if wrong.
Dreamshock is more ex comparing same specs? Excluding brand comparison.
Audiology93
Aftershock RTS is quite value for money from time to time. Gotta keep a lookout for it.
Sent from Xiaomi Mi 11 using GAGT
EmPtYsOuLz
If you're not particular about specific components or a few dollars of savings, I'll go for aftershock/dreamcore
No need to worry about hardware part availability and can just bring down for troubleshooting if anything goes wrong
tigerwoods
I just ordered my first Aftershock RTS 5800X PC + RTX 3070 OC, hope everthing is working fine when delivered.
katoboy
The case is Lian li 011 mini or the 011 dynamic heard that you can buy the fans or power supply you prefer fir them to install too.
localITguy
Suspended
i wish u all the best, for my case, it came with issues. have to send it twice! for rectify.
do update here
tigerwoods
RTS models you can't change that's what I know
Posted from PCWX using iPhone 1000 Pro Max
