Option rolling
proton91
Hi all, new to the options game and trying to figure how the bidding and asking work if I want to roll a call option.
Say I bought a 20C for 5 Mar at $2.50 and I want to roll the option to the same strike price for a week later that is priced at $3.50 - how do I go about setting an order for this transaction?
Do I select the option to roll option, select these two legs and submit a buy order for $1.00? Ie the difference between the two contacts price?
Currently using IBKR.
To keep it simple for now .
Buy back current to close it at same price and date. You can see that it had been negated after you done it .
Then you sell call again
Shiny Things
Yep, that's exactly right - the Rollover Options tool is the "default" way to do this.
You can also just set up a spread order between the 5-Mar 20-strike call and the 12-Mar 20-strike call, and bid $1 for the spread; you'll end up in the same place.
loackerc
I think he's doing long call. So sell, then buy.
moolala
whats the adv of using the rollover tool? seems complicated, unnecessary
i just close it and open the other like what u said, a spread order
