Weighted blanket - who use this before ?
  • Need someone to talk to?
FireEmblem
Just got to know bout this kind blanket which is heavy and helps u to sleep better via reduce stress etc
Who uses before this type ah?
U feel got effect?
DulanMax
Hear people say good before but dont understand how is it supposed to work.
Blanket got weight then??? :s11:
tauntme
Yes it works for me (maybe placebo) but damn tedious to make up the bed
FireEmblem
Is like got the blanket to weigh u down abit, so your body has less movement and sleep easier
kumokumo
Only need 1 small hole, then all the material inside spill out all over ur bed.
FireEmblem
Supposedly get a weighted blanket that is 10% of your body weight
Artemm
I have one sitting in the cupboard. I sleep in aircon room and always wake up drenched in sweat. It's a hassle to move it around too. Usually people use it for anxiety and it helped me during stressful period. Another method is to sleep with a pillow on top of you, feels kind of the same as weighted blanket.
FireEmblem
Aiyo, buy quilt/blanket cover then ok le mah. Since it is weighted like 7 kg up, the material sure also is tougher mah
m/mink
It's a thick heavy blanket kind of thing to keep you in place, supposedly help to sleep better.. But imagine the heat?
