So fast page 13 Liao
Gxgx ROW kor kor for being the first poster![]()
This seems to apply to anywhere also? See heng suay.
True is more potential to grow, but no work life balance one, especially the higher you climb. My email forever synced to phone, go medical/hospitalisation leave also still responding/attending calls on phone. Last time go overseas holiday also got people still contacting me.
Unlike I see my other friend... in CS on leave nobody will ka jiao you. Weekends also no need to work one.
Same la.. im just about one man show.. very sian sometimes. One can only take so much responsibilities.
At least your pay surely very high. Mine is....
thats just tools, and a very small part of it.........
SQL is used for data extraction............
data engineering has it call ETL extract transform load.........
so like extract all female patron between 2019 2020 sale record...... transform into a standard format and load into the pipeline.............
pipeline will then process.......
SQL can be use in spark jobs...... spark support python java and something i forget 3 languages......
so maybe they can store in hadoop using query engine like pig or hive(has SQL like query)..... code can connect to hadoop using hive or pig query....... extract all the data and then stream each record to maybe like kafka...... spark job will literally take each record and broadcast on a messaging system like kafka.....
there are many ways and many options.... each have pros and cons for different scenario and use case...... maybe the data analysis is a time series..... a weekly data report...... then will have some set of tools and framework..... maybe some data is large image dataset then will have another suitable set of tools and framework...........
SQL SEQUEL is structured querys...... there maybe unstructure, semi structure data..... some need data consistency, some need high availability, some need partition........ then will have different database....... HBase, Cassandra, mongol, relational DB.... all store records tuples different and may or maynot use SQL.......
some maybe use data partitioning, some may use data shard...... to keep on different database servers..... then have some kind of registry and cluster to serve different querys...........
At least your pay surely very high. Mine is....![]()
Can I have a potty break?
丑人多做怪, 懒人屎尿多
So sad, these Chinese verse suit me so well
丑人多做怪, 懒人屎尿多
Mostly chit chat these days.
If you want your bazi to be read, can pm TUV with your dob, and gender. Tell him if you can read mandarin or not.
Remember to clear your inbox, dont make him type a lot then realise cannot send to you
If want to read zwds, can pm dogz with your dob.
Wa hahah thank you!!
But who is TUV?
Anyway hi everyone!
Hello kik i already read for u liao u still find 2nd opinion
Btw this one is super chiobu with eyebags still pretty wo ai ni
Everything is in the mind.
要有雄心壮志,还是小富即安。
每个人追求的东西不一样。没有对错。
With current life expectancies, u could start out at 50 and still achieve decent success by 60. Its never too late.
But who is TUV?
Anyway hi everyone!
Old bird always bully new bird one.
Start young better![]()
Private sector can earn much higher pay though, especially if you are in mnc.
要有雄心壮志,还是小富即安。
每个人追求的东西不一样。没有对错。
