My mitsubishi aircon (system 3) gas leak
1st march top up gas from 80psi to 150psi
today check left 50psi
any affordable solution to arrest/repair the gas leak? (lot's of conceal ducting)
TIA
If a service person detects that you have a low PSI, the first thing you have to do is quickly contact the original installers. Usually when installing an aircon and having a new piping is that you will also get 1 year's workmanship on the installation. So for example, for the piping, within that one year, you realize the aircon installer company play punk by hiding any opened trunks hidden at the side of the window or at the bottom, you can quickly call them up and request them to have this issue rectified within that 1 year.
Remember, even having any gaps in your trunking which means that it is not sealed will cause warm air from any part of the house that has the trunking to seep through the open gap and can quickly cause your insulation to get overwhelmed by the difference in temperature between the cool pipe and the warm air that is now in the trunking. Thus causing leaking on your trunking more quicker in the future.
Similarly, if there is a case where your gas PSI is lower, it means that there was bad workmanship on the installation of the pipe that cause the leaking. And as per the warranty for workmanship, the aircon installer for the piping MUST come back to fix this issue for free.
Depending on the company that you engage, there are quite a number of these companies that play this game. Because 'gas top-ups' makes them lots of money when you engage their maintenance service next time.
As I've mentioned in a very detailed post earlier this year gas top-ups should not be a common thing. In fact, it should never happen at all. If you know a bit about computers, you should know that like fridges, the gas is in a
closed-loop system. Have you ever needed to top up the gas on your fridge? No right? Exactly. It is a sign that there is a leak in your piping. The gas can be toxic to humans especially in an enclosed room. Not to mention, they are knowingly and willingly polluting and damaging the ozone by letting these gases leak into the air just to get more money out of you when you call for maintenance on your not so cooling aircon.
Absolutely disgusting tactics.
Please do check your trunking properly especially at hidden corners where they can leave a gap to make your trunking leak sooner too. Because you seem to be unlucky to have an installer that even caused your piping to leak and knowingly poisoning you along with making Singapore hotter by damaging our ozone layer right above our heads.
