Any 34" ultrawide monitor 1440p with HDR, G-sync/Freesync 144Mhz with PIP/PBP?
tremor
So far I only found the AOC CU34G2X has all these features, but its quite fugly. I don't like the red streaks all over the monitor.
Any other recommendations?
tremor
Ok seems like gigabyte G34WQC and prism plus x340 pro 144 also has pbp and pip.
Since 3 are similar price. Any feedback which one is a better buy?
Elijahonli
Honest opinion, dont buy for the HDR. Any monitor with below 600nits peak brightness cant show display HDR content accurately which makes it pointless. Out of the options, i think the gigabyte would be the better option
tremor
I’m using ips panel now. Not sure if go to va panel will have big difference or not. Ips seems like twice the price of va.
congster2
Elijahoni is right. Unless you are prepared to shell out thousands for the highest end monitors that can go really bright, the HDR label is quite pointless. Even for those that do, I’ve not seen one that has implemented fald really well, so blooming is quite obvious.
IPS monitors are known for better colour accuracy and better viewing angles, but the compromise is usually speed/refresh rates. No free lunch. A good quality high refresh 1440p ips panel usually costs a pretty penny.
tremor
Ok then I don’t know lah. Don’t change monitor for now. Wait another generation.
Elijahonli
tbh i cant really see the difference between VA and IPS in terms of the ghosting etc. Colors are definitely better on the IPS but not to a huge margin. If you are looking at for a cheap ultrawide option, you can definitely look at the gigabyte.
styrwr9!
VA panels have improved over the years to match the response time and improve the ghosting problem, it still there, just hardly noticeable
agree on the colors on IPS are better, but unless you are doing creative contents, it doesnt really matter
tremor
last month acer clear stocks of x35 with all your requirements, at $2.3k after platform vouchers
think new version coming with samsung 32:9 panel, best is have hdr 2000 mini-led! :s14:
https://videocardz.com/newz/acer-ei...r-features-vesa-displayhdr-2000-certification
No lah 49” is too big. My desk don’t have the real estate.
anyway I found the monitor I want and buy liao. The new acer predator x34 GS. $1450. Tmr night deliver to me. Just now go sls walk walk and founded it.
oohmygod
This predator x34GS monitor got freesync?? Because it only mentioned g-sync in the spec.
tremor
It has adaptive sync so I supposed it works with both. I have nvidia card so cannot verify for u
