cassowary18
- Jul 17, 2018
Three cards with very similar earn mechanics, let's compare!
UOB EVOL
Analysis:
For the sake of this analysis, we'll assume that your spending is split roughly equally between contactless and online spending, and we'll ignore the "all other spend" category.
UOB EVOL has the highest headline earn rate but once you look closely at the earn cap you'll realise that it is impossible to get an effective cashback rate of 8%, since you'll max out at $500 total spending. For all the other cards, you can hit the minimum spend without hitting the cashback cap if you split your spending roughly equally between contactless and online spending.
Assuming you clock just enough to get over the minimum spend of $600, your effective cashback rate is (40/600 = 6.67%). Not too shabby but certainly not 8%. Your effective cashback rate for the UOB EVOL drops to less than 6% when you spend more than $666.67 per month. In this case, you should just use OCBC FRANK from the beginning.
So here's which card I think you should choose.
If your monthly spending is:
UOB EVOL
- 8% on mobile contactless spending (excludes Visa PayWave) - capped at $20 (i.e. maxed out at $250 spending)
- 8% on online spending - capped at $20 (i.e. maxed out at $250 spending)
- 0.3% on all other spend - capped at $20
- Minimum spend of $600
- 6% on mobile contactless spending (excludes Visa PayWave) and in-store foreign currency spending (we'll ignore this one - very difficult during this time anyway) - capped at $25 (i.e. maxed out at $416.66 spending)
- 6% on online spending - capped at $25 (i.e. maxed out at $416.66 spending)
- 0.3% on all other spend - capped at $25
- 5% on contactless spending (includes Visa PayWave) - capped at $20 (i.e. maxed out at $400 spending)
- 5% on online spending - capped at $20 (i.e. maxed out at $400 spending)
Analysis:
- $600-$666.67: UOB EVOL
- $666.67-$833.32: OCBC FRANK
