What are the usual speed (during day time and peak hours) you guys are getting from your M1 1Gbps plan?
I have been on this plan for so many years but have always been using wifi and never bother to check the speed. Until recently, I went on wired connection but to my surprise I am getting...
- 250mbps to 360mbps during day time and peak hours
And so I begin more research and troubleshooting to get as high a speed as possible using:
- 3 different laptops' RJ45 ports. Result: no different
- Using 3 different Cat6A, Cat6 and Cat8 cables. Result: negligible differences
- Tweaking asus router configuration. Result: doesn't help
- Tweaking Win10 settings. Result: no improvement
Until after weeks of troubleshooting... I decided to test at different timings and lo and behold...
- speed jumped to 700-860mbps between 2am to 6am
- but after 6am, speed went back to the 250-360mbps range throughout the remaining day and night
- this observation occurs throughout numerous days of testing over last one week
Could M1 have been throttling bandwidth at different timing? Or could it be due to WFH, day time's and evening time's consumption of bandwidth far exceed allocated bandwidth in my block/vicinity/neighborhood?
If it is the latter, shouldn't M1 allocate more bandwidth since nowadays WFH is the new norm and is this something that we as customers can feedback to IMDA for M1 to improve on?
Anyway, as my experimentation continues, I found out that I can further improve speed by making the following changes.
- Disabling Malwarebytes' Web Protection while keeping malware, ransomware and exploit protection enabled - this speed up around 50mbps which is quite visible
- Disabling Kaspersky's Web Antivirus, Network Attack Blocker, IM Antivirus and everything else except File Antivirus - this improved speed by as much as 100mbps
- Disabling Tiny Firewall - this improve around 10-20mbps which is negligible
By making the above 3 changes, I managed to get max speed of
920mbps between 2am-6am. But it makes no different during day/evening time which is still frustratingly 250-360mbps.
Just wanted to highlight that, these changes compromises security and definitely not recommended as a day-to-day contingency. So what I will do as a next step, is to uninstall Malwarebytes and Kaspersky altogether, and then fall back to the good old Windows Defender which according to AV test is more lightweight on system resources and doesn't impact web activities as much as MWB & KAV while on the other hand, still on par in terms of detection rate. This alternative remains to be tested in the coming week.
As for Tiny Firewall which is crucial to prevent all the hidden rogue software from phoning home as well as asus router's firewall where only DOS protection is enabled with no visible impact on internet speed, I'll probably keep them for now until I have time to build a pfsense or opnsense box for hobby's sake though not as much of a reason for speed improvement since the gains if any are negligible compared to the priority at hand to sort it out with M1 on why such huge different in speed at different timing.
Note: all above tests are done with wifi disabled on router which gives no opportunity for mobile or IOT devices to compete for bandwidth when tests were being carried out.
