IWDA/VWRA/ISAC ETF - Some of the Best ETF
wutawa
You've been told countless of times to stop spamming this thread. There's a red/green thread for your "bump for sake of bumping" parrotting.
Just put him to block if it affects u. I only hope he is earning money with these spams instead of using the time to manage his investment. Hehe
can i know why are people shifting from iwda+eimi to isac?
previously people was hesitant to shift from iwda+eimi to VWRA because of the increase in TER. and since now isac TER is only 0.2%, i guess thats one of the main reason to switch over?
ideally a couple of hundreds every month but i dont think there is an rsp for this? so have to go through broker, but broker if you go into few hundreds every month, the cost will be high. so logically, you should go in with say maybe 5k every 3-6 months and with scb? is the assumption correct?
actually isac is 0.18% and IWDA and EMI each is 0.2%
Not much option for UK listed counters that are cheap.. so typically people here i think use IBKR or SCB.
Don't have SGD one.
if I have a lot of US shares, it's better for me to lean towards EIMI rather than IWDA/ISAC since I'd be overlapping close to 40% right?
reddevil0728
I compared the returns are similar but if annualized 1 or 3 years, EIMI is better.
Also for diversification purposes la..
Is there any other objective apart from returns and diversification that I may have overlooked? THanks
Past performance is not an indication of future outcomes.
so looking at past returns doesn’t mean a thing.
who knows? Can tank from tmr. Or can go to the moon tmr vis-a-vis other options.
it’s about what you are betting on?
in the past the returns around the same.
do you expect EM to chiong ahead? Or DM to chiong ahead.
