Prefix delegation size for M1 is /64Anyone setup IPv6 on Unifi USG or UDM/Pro? I just signed up with M1 and would like to know the Prefix Delegation size that M1 uses. Thanks
I will give it a try once the service is up and running. Many thanks!Prefix delegation size for M1 is /64
It happened to my bro M1 connection before. Even changing router doesn't help.hihi, not sure if this is the correct place to post, my M1 broadband connection kept dropping around afternoon to evening time ever since WFH started, sometimes once 1-2hours, sometimes every 5 minutes. Is this common? Called M1 and they checked and said there's nothing wrong with their service.
using ASUS RT-AX88U router. high floor (>30 floor).
My contract still has about 2 months before expiry; if this is common from M1 I will look for another provider.
Thanks in advance if anyone can shed some light on this!
This is not common and should not occur. As jasonho mentioned it might be caused by a faulty modem/ont. If the modem is faulty, M1 should replace it for you for free.hihi, not sure if this is the correct place to post, my M1 broadband connection kept dropping around afternoon to evening time ever since WFH started, sometimes once 1-2hours, sometimes every 5 minutes. Is this common? Called M1 and they checked and said there's nothing wrong with their service.
My side at North East also facing this issue. my download and upload is 600Mbps and below and when the technician come down, it is shocking to hear that is the typcal speed when getting their 1Gbps plan.
anyone have any idea what is the committed speed for 1Gbps plan for M1?
On wifi or wired?My side at North East also facing this issue. my download and upload is 600Mbps and below and when the technician come down, it is shocking to hear that is the typcal speed when getting their 1Gbps plan.
I am not sure if you are getting the speed when the device is connected via wired or wireless connection? If you want to know the actual speed, you need to test via wired connection, not wireless. Wireless connection speed is very subjected to any device interference, your router and your mobile device. So its not a good measure.My side at North East also facing this issue. my download and upload is 600Mbps and below and when the technician come down, it is shocking to hear that is the typcal speed when getting their 1Gbps plan.
Thanks to Jason. I think I will call the technician down to checkThis is not common and should not occur. As jasonho mentioned it might be caused by a faulty modem/ont. If the modem is faulty, M1 should replace it for you for free.
But such problems could also be caused by your own router or wifi signal which would not be M1's fault or within their remit to fix. Try with a wired connection to the router if you can, and see if problems still occur.
So right, similiar to "rubbish in, rubbish out" - term borrowed from HiFi reference now applicable to WiFi. The strongest Link is your starting point so in this case, the strongest is your wired access. Mine below is OK! (for ref.)I am not sure if you are getting the speed when the device is connected via wired or wireless connection? If you want to know the actual speed, you need to test via wired connection, not wireless. Wireless connection speed is very subjected to any device interference, your router and your mobile device. So its not a good measure.
As far as i'm aware, neither come with a free router. I believe M1 bundle a phone line whereas Starhub do not.which is 500MB plan is better, the M1 version or the Starhub version.
Which one come with free router.
Any WiFi 6 router to recommend for 500mbps?
Don't worry about free routers, if the ISP is giving it away for free that should tell you something. You're much better off buying a decent router off the shelf. You'll have more choices, and you'll be able to reuse the router with any provider - some of the ones supplied by ISPs are locked to their service and become e-waste if you switch providers.
