how to fix old drill holes in ceramic tiles?
antonpoh
how to make it as close to the ceramic tile's finish as possible?
:frown:
Just use back that hole and put this.
zzzzzzz
best is use white putty for light coloured tiles rah :frown:
then colour it to the nearest colour...
after that ask chiur mummy to check if she notices it :s13:
i stay alone and know where all the holes are and i always will notice it
:frown:
mooseolly
Professional use a kind of chalk which under heat (some use iron) to melt it and fill up the hole. After that they use a buffer to polish the spot until shiny.
sTiCkY
:frown:
that's why patch riao ask third party see :s13:
usually won't notice ones... means success.... chiu have to live with chiur demons :s13:
Atrina_Boy
Use those puty brand
ust use sand paper to sand off after dry to flat it
NTUC selling
theAnonymous
but then hor... got hole already. even if put cement or watever over, still fugly..
Prof. Utonium
can't exactly fix it if you dont have spare tiles.
can be quite an eyesore, colour it if really bth.
