how to fix old drill holes in ceramic tiles?
New Eden
will drop off or not?
kitchen area and toilets with wood tiles can? wont spoil?
:frown:
if wet area go buy those acrylic or plastic tiles piece can diy overlay the wall.
go google search "adhesive DIY wall tiles" or something
Taloona
I an facing the same problem after changing my shower set to a rain shower. The stupid beng plumber removed the old set and left a big gaping hole, then patch it with a white putty which stood out like a sore thumb against the light brown tile! I think I am going to buy wall stickers to cover it !
fluid_motion
yes, but will leave a mark after patched with white cement
i want to make it as close to original finish of the ceramic tile as possible
:frown:
Depends on the colour and texture of the existing ceramic tile. Most simple method will be using similar coloured putty filler material to patch, dry then sand. No perfect way unless you change all the tiles. This is similar to painting scratched up door on car; you either paint the door to match the entire car or paint the whole car. :(
grotesqueness
Considering thish ish edmw, i was scrolling rooking thish kind of reply.
Was not disappointed.
hey
i got this idea from US TV show "hack my dick life"
images
Handyman8888
Use tile grout. It comes in powder form with many colors. If you want to get the closest right color, you got to mix two different colored grout or use white powder grout to lighten the color you want.
Sold in business for building material for contractor like Buildmate etc Not those atas inside mall kind of place.😆😆😆😆😆
New Eden
ya actually this is like wall paper
do u know whether got messy residue when time to take it off?
:frown:
why want to take off? just overlay again ma.
if take off i suspect the glue might become yellowish from beneath.
KPO_SAHM
My kids dug and peeled off the outer layer of my wall. Many holes around. Some as big as a palm size. How to fixed that huh???
KPO_SAHM
I even have rusty nail stuck onto tiles . Tried to pull of old nail but it just broke into 2 and I could not remove the other part tat stuck onto the wall. Anyone can help beside hacking or dugig a big hole to remove it
zzzzzzz
might have to use a drill to drill out the broken nail
:frown:
antonpoh
yes i got watch this video
sg got contractor who can do this and who can find back old hdb tiles?
the one i ask no want to do for me
:frown:
Many contractor can't just take out 1-2 tiles. Sometimes they may crack the adjacent tiles.
If you DIY this, maybe could cost less than $50. Old hdb tiles are easy to get, white square tiles I mean.
