wwenze
- Dec 2, 2002
For the first time the delivery is not in a 20kg box, that's refreshing.
Oh hey it says Bluetooth 5.0 on the box.
Unboxing
And that remote control... oh wait...
Wow...
This makes R2000DB's remote look cheap in comparison.
It even has a model number... I wonder if it works on other speakers too, hmm...
Continuing with the more boring photos, the side and the knobs are what you already know.
The back, which is pretty normal. Being a cheaper speaker, there is no bi-amping this time, so the simple red-black spring terminals. Two line-in, coaxial and optical, which now has a built-in cover which I like because I hate having to care about the cover, and a sub-out
Wait what...
A sub out?
Is that what the "s" in R1280DBs means?
Or does the s stand for the new Soundfield Spacializer which I used for 2 seconds and never used again?
Or does the s just stand for "second edition"? Oh wait, they like to use "MKII" for that.
Whatever the case, this thing has a sub out. And a pretty smart one too:
We'll see what it does with measurements later.When connected the sub-out automatically detects the subwoofer and activates the digital crossover.
Subjective listening 1
For a quick and dirty setup, I just placed them where space was available. And used BT from my phone. 16-bit 48kHz with SBC codec, because aptX costs money to include and now we also know it doesn't necessarily sound better. I forgot to measure latency.
I've stopped using this placement for direct comparison, because the upper speaker does not benefit from table bounce and usually ends up sounding worse than the lower speaker.
But R1280DBs sounds pretty good out of the box like that. That's a good start already. So far majority of speakers sounded poor in that position, so if R1280DBs sounds good there, it will also sound good in the living room, or on a shelf, or basically anywhere where table bounce / floor bounce is not as available. And this is achieved while being just a 4-incher, too.
When I say sounds pretty good, I'm referring to the overall feeling. Sufficient bass (Actually very good bass for the size + price, as we will soon confirm with measurements later), no bloatedness, no ear-bleeding, nothing really stands out. Until I noticed, "Where's the treble?" It's not totally muffled like many tweeterless speakers, in which case the treble is totally missing. With R1280DBs though, the treble is still there, but lower in volume. Measurements both confirms and finds something interesting tho, so this is going to make the testing less straightforward. I'll cut the needless chatter - The grille interferes with the treble. And not by a small amount either.
