Is it correct that BUTTER also can turn mouldy even if you put in fridge?
asiafrenz
Didn't know till i saw my newly cut butter placed in a click-lock container show dots of black stuff (which i think is mould) after a week of not using the butter for bread, end up throwing it away :mad:
Canis Lupus
Dun say butter, moi eber put one tub of olive margarine in fridge osho can becum moldy, mold is bright red like bubble..:(
tinykukubird
Mine can put many months
begintoend
think your butter knife or utensils are dirty :crazy:
tanahgu
u contaminate the butter chunk with bread bits or saliva on the knife
i always buy abt 8 x 250g blocks and they last 2 months in my fridge
RedOrion
Your fridge contaminated? Or you keep your butter exposed inside the fridge? Most folks able to keep butter for 1 - 2 months?
asiafrenz
my other stuffs in fridge ok, no issue with mould, only the butter. Maybe i should try again with another new piece of butter see how
limpeh456
if temperature is hot enough, sai 's bacteria also died and the sai safe for u to eat
if temperature is cold enough, sai' s bacteria dun multiply
BlackWing1977
Too much moisture lor...
BlackWing1977
Now butter too expensive lar... I stop buying them liao... rather spend the money on cheese slices instead.. cheaper...
asiafrenz
so looks like the issue might have been water from the butter knife cause the mould on the butter
