Unblock TV Discussion Thread III [consolidated]
tbs
Svi vs ez pad. What’s the difference? Any preference for brand?
tak
Anyone encounter uB live lagging or stop these few days? Mine drop to 1kbs or stop streaming after 30 sec or 1 min of streaming... Happen in most channel I select... Been using the pro2 for 3-4 years, any solution? Seem like m1 blocking it..
gregory_choo
recently singtel and m1 started to block ub servers, so you have to use vpn, set to other country, to unblock the block.
左青龙右白虎
If you can understand Mandarin. A review of some recent boxes.
Here mostly we have evpad and unblock tech.
SVI, my friend is using as compare to both, it's performance is better.
第四台 is just live channels. All boxes deliver almost same quality resolution due to bandwidth and servers.
Next look at frequency of updated movies and the quality resolution. Some have 4k movies.
Ease of used. Especially for elders or support voice control.
Netflix, Disney+, etc certification support code if you want side load them.
For me, I just using a Amlogic S905x3 tv box and buy IPTV subscription online instead since nowadays more affordable. These tv boxes specifications are often higher and allow more free play such as configuring them to retro gaming devices and Android based gaming or application.
Just such YouTube, there are many recommendation. For subscription, just go Lazada or Shoopee search and see the reviews yourself and get free trial or paid a token sum to test first.
In case of VPN block by our ISP, earlier post, I had posted using Quickfox VPN to access China websites such as Iqiyi, tencent, youku, etc.
Paid VPN, best is Expressvpn but pricy. Surfshark has unlimited devices connection and people selling them online at one off price per device.
You can also configure your own VPN do some homework on web.
Read HWZ Forum Rules!
hungryfella
sorry, just needed to check..
How to download vpn onto the box?
im a tech noob & never use android before..
Thks in advance..
左青龙右白虎
Thks in advance..
Your android tv box has google play store right? Just go in search Quickfox. If you want to subscribe plan, than ExpressVPN, Nordvpn, Ghost, Surfshark are reliable.
There are free VPN with ads like speedtest ookla inbuilt, windscribe, etc. But bandwidth and datas given are limited.
Once download just select a location country and connect will do. Go YouTube search to watch. Once installed, run the VPN first to select the country server than open your application. This is just one advantage of VPN. Beside that is for security and hiding your IP. Just google and read.
Recently there is a new local VPN company Ivacy. Can consider subscribing as it comes with 2TB cloud storage.
You can unblock region control like Netflix, Disney plus, BBC iplayer, etc.
Of course paid VPN is better, more countries, more servers, unlimited data used, bandwidth and stability, and can use on multiple devices like your hp too.
hungryfella
thank you very much for the information!
will be getting my ubox soon..
Hope that my telco did not block the channels..
左青龙右白虎
If you buying unblock tech should not have any problem. Don't have to use VPN. Beside if I remember, the inapp store has a VPN application for you to use too if you face any problem to connect.
If Telco problem, you can easily change your router DNS to Google or Cloud. That's another story.
Just try first, anyway there is a local distributor in Sim Lim and warranty for your set and the sales rep can teach you too.
Some boxes because of IP rights, it may be a raw set without the application. You may need to download yourself but it is an easy process. TV box is a legal commodity to purchase just like you buy a new handphone and later install your own apps from google store or apple store or 3rd party support.
Walchwil
I am currently using the UB Pro and i am stuck at the logo screen when I turn it on.
Had tried to pull out the power and unplug the power source still not working.
gregory_choo
go to recovery menu and execute factory reset.
if cannot work, flash the box with new firmware
rainforest
Hi my ubox cannot power up, can i use another ac/dc adapter with a output 12v 1.5amp to test. The original adapter output 5v 1.5amp. Thanks.
gregory_choo
No. You need a 5V adaptor. If you cannot find 1.5A, 2A or more is OK>
terry2005
Hi, currently using UBox 4, the UBLive keeps buffering. Considering whether to change to UBox 9 or not. Any suggestions?
Iamatlarge
Hi everyone-
very sorry if I might sound silly but have some questions-
I recently got a hand-me-down KazTV from my pal because he upgraded to EvPad 6pro.
I just wanna find out anyone got experience in this brand?
I am looking in getting a box. Main for Watching streaming English chinese movies and adult content (without other apps). I do not think this KazTv be about to do that.
anyone can enlighten me or let me know a preferred model for these purpose?
thank you very much in advance!
gregory_choo
Hi everyone-
it is just a standard android box, just install the right apps. There are plenty of them available.
RayOfLight
I have been using ubox 8 for quite awhile. the box always hang after sometime and I need to reboot. could be box too hot I guess? anyone encounter such issue? also keep buffering which can be quite irritating. any solution?
hungryfella
i just bought ubox8 last month..
So far not impressed with it..
many channels dont even load, just black screen.
Those that manage to load, keep hanging, lagging, & reloading.
im using 500mbps connection so dont think it is an internet problem.
the videos on demand work ok though..
but that offers scant consolation as i primarily wanted the ubox for live soccer channels.
chiaps
UBox 9 is now available at about the same price as UBox 8 or just marginally higher. UBLive now comes with HD and 2K channels. ;)
