thisislife
- Jun 7, 2007
i installed deco m5 x2
no need go wired mode, just wireless can liao
Hi all, beginner to home networking here.
Just got a resale (5 years old) flat and trying to navigate the best networking strategy here.
I'm planning to get a 1gbs plan from Singtel together with the Wifi 6 Asus router. Is it true that singtel comes with ONR so my setup can be;
TP -> ONR -> Patch panel -> Asus router in living room.
Will this setup work and can I reap the most benefit from the Wifi 6 with this setup?
I'm also worried that the master bedroom is too far from the router, how can I improve the setup? I got a lan port in all of the room currently.
Thanks
My friend’s ID work. Any idea on why the electrician lay the two LAN cables directly out from the trunking instead of through the box?
Btw the FTP is like that because carpentry work block the access point.![]()
Hi Guys, I am new to networking here, but will be getting a new BTO soon. I have ASUS AX88 currently and planning to use it as my main router.
I read from the group mention that we should put a weak router in DB box to connect to ONT and leave the stronger one AX88 as a node. However I also read somewhere that in AIMesh setup, the stronger router should be the primary node. This is a little conflict with the above recommendation. How bad is the performance if we use weak router as primary node.
I am also planning to use Wired Backhual in my new place.
there are 2 lan points but there are meters apart. so you need to move one of them or to lay another new cable.2 LAN point at living room, is it something new BTO equip with or this need to bring in contractor to install it?
Thank you for the advice. Yes I will probably go for the dual LAN option to link it back to my DB box, and do a wired backhual from bedroom. Just thinking that the LAN route is a little long from ONT to living room then going all the way back to the switch in the box and then to the room LAN for the 2nd Node.
Dear gurus,
Please advise a newbie here. I have gotten my BTO with the TP located in the DB by the main door. The intent is to be able to use the ethernet ports in the DB without installing new ethernet points or using ONR from Singtel.
I am thinking of the following config: TP -> ONT -> router in DB -> mesh router as AP in hall (via ethernet) -> mesh AP outside bedrooms, and, ethernet into a range extender config as AP in the master room if mesh coverage not good.
Qn: Does the WiFi speed of the router (in the DB) matter if i am just using it as a means to use the ethernet ports? meaning can i get one rated at 300mbps and yet get higher speeds on the mesh APs since it is a "pass through" from ONT to AP via ethernet?
Hi, I am trying to avoid using Singtel although their ONR is the simplest solution.If your device are all connected to the mesh router. The wifi speed for the “router in DB” don’t matter.
Your singtel is ONT or ONR? Saw the first part talking ONR then 2nd part ONT.
Thanks guru!Which router you intend to put in the DB box? It is correct that the wireless spec of the router in the DB box does not matter. However, the CPU and RAM may matter, depending on the feature you want.
Cheapst one and lowest end router in the DB box I would recommend: Linksys EA7500 V2, Linksys EA8100 V1 and Asus RT-AC2600, etc, they all have the low end Dual Core MIPS CPU at 880MHz, and 256MB RAM.
Better one to use: Asus RT-AX56U with Tri-core ARM Cortex A7 CPU at 1.5GHz and 512MB RAM.
Thanks guru!
If I get a tri band DDWRT router in the DB, and configure 1 band with VPN, will the VPN be passed through to the Tri band APs?
Intent is to switch network to watch different Netflix selections and other geo restricted content.
there are 8 wires in the cable, if one of them is faulty, then you will get 100Mbps.Hello all,
Wanted to ask about the existing lan ports in new HDB homes.
My computer lan speed detected is 100mpbs. I have checked the computer lan card and its supporting up to 2.5gbps, and lan cable used is cat7. May I know what is causing the detected 100mpbs? could it be the internal hdb cables used or the lan port outlet to support only 100mpbs?
My current setup -
Viewqwest 1Gbps - installed at db box and router connected to 2 lan ports for study room desktop direct connection.
Study room - direct lan connection from data point.
