Sure. Will quote for u base of 500k death/tpd as well, due to large sum discount, sometime with base 500k, it will be cheaper than 300k.Male / 30 Next birthday / Non smoker
Looking to purchase term plan no need ILP mainly to cover myself for CI till age 65. Can quote me?
Death/TPD: 300k
CI: 200k
ECI: 100k
Death/TPD: 300k
CI: 300k
Hello sure! Will quote you on this 2 configurationsMale / 30 Next birthday / Non smoker
Death/TPD: 300k
CI: 200k
ECI: 100k
Death/TPD: 300k
CI: 300k
YesSorry new here what is
A
T
M
X
C ? Is it different company?
Aia and ntuc is not competitive thus did not put into consideration, if u wan can quote for u. And i cant quote ge. Ge only ge can quote, they dont give any fa company to distribute.okay thanks, how about other company,like AIA ,NTUC, GE?
Hi. Here are the quotes for GE’s term.okay thanks, how about other company,like AIA ,NTUC, GE?
Not necessarily. GE’s term for $1m Death and higher is really competitive especially with our ECI. I believe our ECI should be one of the more competitive options around.AIA ,NTUC, GE is it these are more expensive as compare with others?
Ntuc and aia yes. GE depends as its quite competitive tooAIA ,NTUC, GE is it these are more expensive as compare with others?
Based on quotations, yeap AIA and NTUC are not that competitive. GE wise, depending on what coverage amount you chooseAIA ,NTUC, GE is it these are more expensive as compare with others?
Its means the eci wil not reduce the coverage for death and tpd while others will reduce accordingly when eci is claim. Which is usually the least concern, because u can add the extra coverage for other insurers and be even cheaper overall. Which also means if other insurers u add 100k more, and if death/tpd happens first, 600k will payout if u add extra 100kwhat is ECI non accelerate?
Hi looking for quotes for the following
1) 28 Male / Non-Smoker
2) 27 Female / Non-Smoker
for both 300k TPD/Death, 300k CI 150K ECI --> Looking for options of multi-claim for CI (possible to quote non multi-claim as well).
cover till age: 70/75
Thank you all so much in advance!
thanks for letting me know! changed to 500k death/tpd.Hello!
For your CI + ECI coverage amount, it cannot exceed the coverage for death/tpd. So in your case, its exceeded by 150k. Thus quotation is not available!
Multipay can only be added to company A's term product!![]()
No worries! will quote for you accordingly.thanks for letting me know! changed to 500k death/tpd.
What are the other companies that offer multipay/claim?
On my end, only Company A has it. Other companies you gotta wait for them to respond to you! I will quote for you those that I can
I assumed the ages are all age next birthday?
