Just test my system under the following condition:
1. Non AC room
2. Sensor
Minimum = System startup
3. Sensor
Current = Idle
4. Sensor
Maximum = 30 min of Ace Combat 7 gaming session
5. CPU 3800x = Undervolted
6. GPU 3080 = Undervolted
Phanteks Enthoo Evolv with Case Fan (Front cover removed) :
1. Front Casing - middle placement: XPG Vento Pro (120mm) connected to Water Pump header = blowing directly to GPU
2. Front Casing - bottom placement: Phantek original case fan (PH-F 140SP) = blowing directly to SSD & HDD
3. CPU fan =
Cooler Master MasterAir MA410M
4. Cooler Master 140mm Air Balance fan for back exhaust
my summary was 3080 GPU really hot hot if playing without AC. UV is best for your GPU nowadays.
