Case has usb c port but Mobo has no usb c header?
wwenze
Connect to USB 2 header lor. Some cases let you, other need to buy adapter.
yusoffb01
587e03535897986156bf0a5090474338
shadow84
Also need to consider the position of your current USB3.0 header on the mobo and its notch location. If not, dun end up the USB C header on this adaptor is facing downwards of your case or in an awkward position. Cant rmb if the internal USB C cable has orientation to follow a not which may result in twisting it.
NightRaven49
What do we call this? like to buy as well lol. My asus rog b550 f gaming no usb c port
guess its just an adaptor. am using one on my b450, pretty cheap at about $3. the seller i got it from also has different directions available, so can just get the one that suits ur case.
xonix
Can use those with flex cable if need to adjust direction
USB_3.0_Internal_20_Pin_to_USB_3.1_Gen_2_Type_E_Female_Adapter_Cable_%282%29__54789_zoom.jpg
