Don't commit too much. Get a trial account firstHow is Sybertv? Wondering shd buy lifetime or 24m subscription..
I got a 2 days trial. It was great 90% with 1 sec lag sometimes on certain channels.Don't commit too much. Get a trial account first
where to subscribe?I m using iptv4k instead of myiptv4k, so far no issue.
Decided to spend more on iptv4k instead of sybertv.
how to sub to iptv4k ?I m using iptv4k instead of myiptv4k, so far no issue.
Joytv and Flyshark tv is basically evpad lar. You can go youtube search for youself and see that Joytv and Flysharktv's user interface is practically the same. I have a evpad box and i tried Joytv trial before. The amount of channels, sequence of channels and non-working channels are 100% the same across both evpad and joytv app.I contacted the svi local seller. He recommended Joy TV. Never heard before so got a trial account. Quite good. Very few channels down. Interface not too bad. But still wanna try others.
Go shopee or lazada, many reseller there.how to sub to iptv4k ?
please share
Whatever it is, it impressed me. Cheap also. 1 year $36 onlyJoytv and Flyshark tv is basically evpad lar. You can go youtube search for youself and see that Joytv and Flysharktv's user interface is practically the same. I have a evpad box and i tried Joytv trial before. The amount of channels, sequence of channels and non-working channels are 100% the same across both evpad and joytv app.
Yes. Now i using fly shark trial account. the interface totally same.. even price also same. I think I'll subscribe to this.. the myiptv one not as good as this..Joytv and Flyshark tv is basically evpad lar. You can go youtube search for youself and see that Joytv and Flysharktv's user interface is practically the same. I have a evpad box and i tried Joytv trial before. The amount of channels, sequence of channels and non-working channels are 100% the same across both evpad and joytv app.
I didn't. I bought thru shopeeis it safe to give your credit card to do some unknown iptv website
Whats the linkI didn't. I bought thru shopee
What iptv app you are running. If you are running m3u player then i suggest you go for stb emu MAG portal iptv app such as ott navigator or iptv extreme. These app allow you to setup mac protal link. you can search for mac portal stb emu from the net and they run very wellWhats the link![]()
I have tivimate ott and IPTV extreme. Just running playlist from githubWhat iptv app you are running. If you are running m3u player then i suggest you go for stb emu MAG portal iptv app such as ott navigator or iptv extreme. These app allow you to setup mac protal link. you can search for mac portal stb emu from the net and they run very well
ok, iptv extreme pm me the mac id. I can help you setup some nice iptvI have tivimate ott and IPTV extreme. Just running playlist from github
How ? Mac I'd is whatok, iptv extreme pm me the mac id. I can help you setup some nice iptv
open your iptv extreme go to setting click the about, you can find the mac idHow ? Mac I'd is what
Is it supposed to be privateopen your iptv extreme go to setting click the about, you can find the mac id
